07-16-2008, 11:38 AM | #1 |
84 Fuel Filter location
I've been trying to locate the Fuel Filter on my truck with little luck (305), anyone happen to know off hand where it is and what the recommended replacement steps are?
07-16-2008, 11:44 AM | #2 |
Arrived on a Pale Horse
Re: 84 Fuel Filter location
That question is pretty vague, depending on whether it's been converted to fuel injection, what brand carb is on it, etc. Without more information, I'm assuming it's bone stock with a q-jet carb. In that case, it's inside the larger hex head cavity just behind where the fuel line goes into the carb, I'll call it the "cannister" for lack of better words. You'll need a flare nut wrench to keep from rounding the fitting off on the line. Totally remove the line from the larger piece, then get a really big wrench and take that other piece out. There's a spring inside of there that you don't want to loose, you'll need it when re-assembled or the filter wont seal correctly. There's also a flat gasket that goes in behind the larger "cannister". Again I'm assuming a previous owner hasn't placed an "in-line" aftermarket filter somewhere.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW Last edited by babyJay; 07-16-2008 at 11:46 AM. |
07-16-2008, 03:14 PM | #3 |
Yeah I looked and looked for one on my '80 (stock 305) and turns out it was partially hidden under the air cleaner. Its right on the front of the carb like babyjay said. Take his advice on the flare nut wrench...I learned the hard way.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
07-16-2008, 03:16 PM | #4 |
My apologies for not being more specific with details, everything is stock (right now at least)....I appreciate the quick responses and help!
07-16-2008, 03:22 PM | #5 |
Meeeeee Tooooooo
No Problem, hope the info is helpful.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
07-16-2008, 04:04 PM | #6 |
Learned what???????....LMAO...how to skin your knuckles in less then 2 seconds?????
07-16-2008, 05:34 PM | #7 |
THE VILLIAGE IDIOT
yup ive learned to cuss reaaly well tryin got get the filters out of the carb... really fun when somebody in the past has rounded off the darned nuts...
honestly honey,,i have no idea how that truck got here. |
