07-17-2008, 01:29 AM | #1 |
huh ???
Tool Definitions
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted part which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, ''What the...??'' ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age. SKILL SAW: A portable cutting tool used to make studs too short. PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters. BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs. HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of. TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper. EIGHT-FOOT LONG YELLOW PINE 2X4: Used for levering an automobile upward off of a trapped hydraulic jack handle. E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use. BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge. TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect. CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle. AVIATION METAL SNIPS: See hacksaw. PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads. STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws. PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. HOSE CUTTER: A tool used to make hoses too short. HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit. MECHANIC''S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while wearing them. DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling ''DAMMIT'' at the top of your lungs. It is also, most often, the next tool that you will need.
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
07-17-2008, 02:27 AM | #2 |
#16876
Re: Tool Definitions
Budweiser. A tool used to extinguish ones vocal cords ability to verbally confront the spouses complaints by numbing the throat and mind thus eliminating the possibility of further confrontation.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
07-17-2008, 10:52 AM | #3 |
great southern land
hahaha thats awsome... soo true but
rod 86 chevy c10 silverado |
07-17-2008, 05:44 PM | #4 |
It Is What It Is,,,,
No doubt.
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den |
07-17-2008, 07:44 PM | #5 |
I have most of those tools in my garage, except the dammit tool I learned years ago tools and the things they hit are too expensive to throw around. however I work with have not learnt this and are fun too watch.
07-17-2008, 08:08 PM | #6 |
Java Mechanic
ANGLE GRINDER: Hand tool intended to make it impossible to hear yous spouse yelling at you while it throws a stream of hot sparks and sets your socks on fire (which may be what your spouse was yelling about.)
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
07-17-2008, 11:03 PM | #7 | |
huh ???
Chuck
07-18-2008, 02:05 AM | #8 |
so true
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
07-18-2008, 12:17 PM | #9 |
~Rest In Peace~
ever see that chick on david letterman that grinds on a metal chess plate ,she cool as hell
i wouldnt mind grinding on her
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
07-18-2008, 12:45 PM | #10 |
Java Mechanic
She's on "America's got Talent" ... she made it past the first cut and will be in the Vegas round.
I thought Hasslehoff was going faint.
