Old 07-21-2008, 11:23 PM   #1
lyrikz
PITbut
lyrikz's Avatar
Can i solid mount my transmission?
Im making a tranny crossmember and wanted to know if i could mount the transmission DIRECTLY to the crossmember. Its a th400 trans with 454 if it matters. It will be driven at least 2/3 times a week. Is it necessary to have the rubber mount in between??? Anyone know where i can get the rubber mount portion if it is necessary???
lyrikz is offline   Reply With Quote
Old 07-21-2008, 11:31 PM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Can i solid mount my transmission?
I wouldnt unless you solid mount you engine too
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 07-22-2008, 12:35 AM   #3
lyrikz
PITbut
lyrikz's Avatar
Any ideas where i can pick one of the rubber mounts up? Im looking at these aftermarket crossmembers and none of em seem to come with the rubber mount portion.
Old 07-22-2008, 12:37 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
any parts store can get it.
If you mou nt the tranny solid, but not the engine, you WILL break the tranny in 2.
Old 07-22-2008, 12:51 AM   #5
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Lyrikz, I have a parts truck with cross member and rubber mount for a TH400 if you want to pull it. I am on the East Hill in Kent.
Is your truck a 3/4 ton? I might have some other parts you may have some interest in as well.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 07-22-2008, 12:48 PM   #6
lyrikz
PITbut
lyrikz's Avatar
I bought some metal to make my own tranny crossmember. Im going to pick up a rubber mount and at least TRY this. If it doesnt work i will let you know.
Old 07-22-2008, 01:24 AM   #7
Ackattack
Ackattack's Avatar
I got a polyurethane tranny mount from summit.
Ackattack is offline   Reply With Quote
Old 07-22-2008, 12:18 PM   #8
70rs/ss
70rs/ss's Avatar
I'd do the urethane mounts as the BBC has a bit o torq and over time will tear the OE replacement types. As for the solid mounting I agree with the above, only if the motor is and then only in a race set-up.
70rs/ss is offline   Reply With Quote
Old 07-22-2008, 12:19 PM   #9
steelhorse
steelhorse's Avatar
Agree with above if you solid mount it the case will probably crack.
steelhorse is offline   Reply With Quote
Old 07-22-2008, 08:03 PM   #10
Longhorn Man
no probably about it... it WILL break the tranny.
Old 07-22-2008, 08:05 PM   #11
lyrikz
PITbut
lyrikz's Avatar
I will definetly have the rubber mount. I will post a quick pic of the Xmember im making.
