Old 07-22-2008, 12:21 PM   #1
aggie91
I'm just glad to be here!
aggie91's Avatar
I want to go Lower
I have a '98 ext cab that I drive everyday. I put drop spindles and a shackel/hanger kit on the rear. I would like to drop the rear about 2-3 more inches and the front about 1-2 more. I am running a 245/40-20 in front and a 275/45-20 in the rear. Both on 8.5" wide rims. The fronts don't have enough backspace for me, but I can live with it at this time since I can't afford new wheels. I will most likely change the front tires to a 245/45-20 so that I can get a little more sidewall.
What do you think are my best (and least expensive) options. I do not have the original hangers anymore.
What do all yall think?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-22-2008, 04:04 PM   #2
aggie91
aggie91's Avatar
Re: I want to go Lower
Here is a Picture from the side.
Karl
The LST Challenge:
Old 07-22-2008, 10:02 PM   #3
RunninLo
3DrDwn--the 'burb not the band
RunninLo's Avatar
pull the shackle/hanger kit and go with a flip kit. that should get the rear where you want it.If not add the shackle kit back in. Then add a drop coil or trim the coils you have now for the front. half a coil = 1" IIRC. Be careful in this day and age of bagged and bodydropped trucks it is very easy to get the full blown low bug.
Josh
Slo and Lo that is the tempo.
'72 burb build page here:
http://67-72chevytrucks.com/vboard/s...d.php?t=259256
'89 GMC Dually crew build page coming soon.
88 4x4 crew DD
duallys past/present pics here:
http://67-72chevytrucks.com/vboard/s...46#post4001246
89 1 ton Dually rear flip kit install here:
http://67-72chevytrucks.com/vboard/s...d.php?t=354327
RunninLo is offline   Reply With Quote
Old 07-22-2008, 10:08 PM   #4
azfab
azfab's Avatar
bagg it..
lifes short fabricate as much as you can!
azfab is offline   Reply With Quote
Old 07-22-2008, 11:30 PM   #5
scotts62
One day...
scotts62's Avatar
I slam it on its kahoonas and bag it!! by the way slick looking truck, those rims look good on it
Scott
93 crew cab build
Project 62
Old 07-23-2008, 12:21 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Put a flip kit on the rear, then install a small air bag to adjust it for loads. Here's my 97 SWB CC with that set up.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-23-2008, 02:28 PM   #7
aggie91
aggie91's Avatar
Thanks for the input guys. Since this is my DD, I do not want to bag it, you know, extra cost and extra stuff to go wrong.
For the flip kit, I would have to get new front factory hangers. Other then a junk yard, where can I get those?
Karl
The LST Challenge:
Old 07-23-2008, 03:42 PM   #8
SCOTI
SCOTI's Avatar
List your current set-up on Craigslist & swap for stock parts.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
