Electrical problem?
I'm losing electrical and the engine is shutting off.
When this happens I have headlights, but no ignition power, no instrument power, no turn signals, & no heater power. At first I thought it was my old alarm system. As sometimes it would just start going off while I was driving. I removed the alarm system and it didn't solve the problem. Then out of nowhere it started working again. So I'm thinking lose connection or bad component somewhere. I checked all the wires the alarm was attached to and everything seems good. Well yesterday I was driving down the street about 45-50mph. The engine died, not sure if the instruments (gauges) went dead or not. I pulled off the road and figured I'd be getting a tow truck. I turned everything off and turned the key. It started right up and I went on my way. Could a bad ignition switch cause this? Bad ground wire somewhere? Distributor (its an MSD, a few years old)? What to look for, where to start?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * Last edited by PHOENIX; 07-24-2008 at 03:47 PM. |
What Hump?
Re: Electrical problem?
I had this problem and it turned out to be the ignition. Do you have tilt wheel steering, does it feel loose? Well on mine it was loose and kept grounding out the ignition. I removed the steering wheel and backing plate and retightened the hex head bolts holding the tilt couple together, fixed the problem. Hope this helps.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
No tilt steering wheel. My truck is seriously lacking options.
I doesn't even have A/C! My gut feeling is ignition switch. Are they easy to replace?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * Last edited by PHOENIX; 07-24-2008 at 05:23 PM. |
Is there any way to test the ignition switch?
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
What Hump?
I don't know of a way to test but it depends on your own ability as to whether it is easy or not. You have to remove the steering wheel, then the plate behind the wheel (you have to remove a lock ring and someties takes a speacil tool) then the signal mechanism is exposed. You then unscrew it from the column, unplug the harness from the overall harness, feed the signal harness up through the column, installation is oposite of removal.
I suggest you head over to the wrecking yard to look at some already apart. Ecology on 27 Ave & Harrison (downtown phx) had several trucks apart, you may even want to pickup a tilt a install it, but thats a different procedure. Hope you find the problem.
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 Last edited by Eyegore; 07-25-2008 at 10:51 AM. |
Thanks for the help Eyegore.
I don't know what years are different, but my '83 has the ignition switch on top of the column, behind the gauges. Here is what i had to do:
I still don't know if this is my problem, but I figured its likely and the part is only $25 (ECHIN, from Napa). Its a USA made switch. I disassembled (ripped apart) the old switch. I couldn't tell for sure is the switch was bad. It did appear worn and some black around one of the contacts. Hopefully its fixed ![]() EDIT (Aug. 1, 08): Well its not fixed. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=301501
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * Last edited by PHOENIX; 08-01-2008 at 11:55 AM. |
Robert Olson Transport
![]() Join Date: Oct 2002
what i would do too for added measure is to wiggle the wires where they go into the firewall and make sure the connection is tight.. also check all the other connections you see but from what you describe im kinda thinking ignition switch myself..
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
