HELP...Broken Intake Bolt
I was swapping Intakes and went to take old one off, put socket on the bolt, started taking loose and the head snapped off. I have about 1/4 inch of bolt sticking out. I tried vise grips and that didn't budge it. Any other ideas? Thanks
71 GMC LWB 350, Dart Pro1's 200/64cc,10.2:1 RPM AirGap, 224/234 @50 496/518 lift w/1.6 roller rockers, 2500 stall '05 Dodge 2500 Crew Cab 4x4, 4 inch lift and 35's CTD |
You could try some penatrating oil or try heating it up. If that don't work, Get a set of easy outs. You can buy just the particular size you need or buy a set. They are very handy.
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins |
go get a can of pb blaster very very good stuff makes wd40 look terrible. soak it down then try the vise grips again. or go get urself a stud remover socket. u could also try a left handed drill bit
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
PB Blaster!, that with a little heat should get it moving again.
There haven't been to many GM's I haven't removed using that method. Mainly because the bolts that break are 1 of the 4 near the thermostat and seize from the coolant corrosion. PB will cut right through that type of corrosion. the heat will make it work a bit faster while expanding the head slightly. basicly do what cableguy recommended and add heat. (just a small propane bottle will do) |
What is PB?
pb blaster is an excellent penetrating lube that is by far better than almost anythign else out there. i havent found anything thats better . i know that stuff has saved me hours of fighting with bolts. stuff that i let soak in wd40 for days and still wouldnt come loos pb blaster had it free in 10 minutes or so and thats not exxageration
d@mn piston ya beat me to it
lol I picked the lazy way...
Where can I buy this in Canada?
have no clue about canada but here in america every auto parts store known carries it
Thanks guys I will go get me some pb blaster in the morning. Piston got it the broken bolt is the first one on the passenger side.
Thanks for all the help. The PB Blaster worked like a champ. Now I can finish swapping my intake. Thanks again guys.
#14 | |
PB is the way to go, NAPA stores have the stuff, use it pretty much everyday ![]() around 4 bucks a can, WD40 is same as using water |
#15 | |
Ed ke6bnl Agua Dulce 70 S.E. Los Angeles 70 Chevy short bed 1948 F3 ford pu 1949 F1 stock V8 flathead 3 on floor 1950 F1 pu street rod 1948 F6 Ford Dually/350sbc no bed stock trans&rear 1972 El Camino 4" chop 1953 Chevy 3100 2b daily driver 1970 SB 4X4 400ci 6in lift |
#16 |
L.E.D. Tail lights, Baby!
EZ-outs
IF you get an easy out, and use it:
DON"T BREAK IT!!! YOu think the bolts are tough to get out... Ezouts become an oxymoron if you break them.
Prov 3:5-8 "Hook 'em" L.E.D. Taillights for sale NOW!!! If interested, visit: www.earlyclassic.com or our website: www.jmcled.com All 67-72 GM Taillights are on sale untill 5 p.m. on Dec 15th, with Guaranteed Christmas delivery! joel.mcwaters@jmcled.com |
