Old 07-29-2008, 01:25 PM   #1
fun in dirt
fun in dirt's Avatar
Steering pump return hose
I'm putting a new power steering pump on my Blazer & thought I would route the return line right while it's off. Right now, it looks like the PO shot the inner fender with a 12 gauge & just ran a straight piece of hard line from the steering box through the hole & to the pump. I'm assuming it's supposed to be a 90 fitting & run under the inner fender. There seems to be room for this. But I can't find a fitting or already made up hose locally. Did y'all have to make the hose up yourself or are they available aftermarket?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 07-29-2008, 01:42 PM   #2
BLUE THUNDER
BLUE THUNDER's Avatar
Re: Steering pump return hose
I bought some power steering hose from autozone and couple of clamps. that works for the return but not the high pressure. Later, Mario.
BLUE THUNDER is offline   Reply With Quote
Old 07-29-2008, 03:08 PM   #3
Classic Bowties
Always on the hunt...
Here is the factory look...
Classic Bowties is offline   Reply With Quote
Old 07-29-2008, 10:34 PM   #4
72lb4x4
I bought both from GMC Paul's. They look the same as the ones in the pics above. The rubber hose part of the low pressure side can be ATF hose and clamps.
72lb4x4 is offline   Reply With Quote
Old 07-30-2008, 09:23 AM   #5
fun in dirt
Thanks for the pics Classic Bowties, it always helps to get that visual.
'85 K30 "Big Nassy"
'06 C1500 WT...DD
Old 07-30-2008, 08:21 PM   #6
dirty trucker
dirty trucker's Avatar
When I bought my lines, the auto-parts store couldn't go back to 1972, so I bought both lines for a 1974 3/4 ton pick-up, they fit almost identical.
dirty trucker is offline   Reply With Quote
Old 08-02-2008, 11:48 AM   #7
69TowRig
I just bought mine last year, I told them it was for a '72 since that's what the donor was when I converted. I got them at Advance Auto parts.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
