Old 07-29-2008, 09:48 PM   #1
jrsmith_2010
I like turtles...
jrsmith_2010's Avatar
Cargo light problem
i am wantin to take out the cargo light in my 79 and fill it and make it smooth. i went to take it out and got confused on the wiring. how is the cargo light and interior light hooked up to the switch by the driver side door? how can i remove the cargo light and keep the interior light hooked up?
jrsmith_2010 is offline   Reply With Quote
Old 07-30-2008, 12:43 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Cargo light problem
The cargo light and interior light wiring are connected. If you want to eliminate it, just cut the cargo section out of it... You will be left with an orange and white wire..
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-30-2008, 10:56 PM   #3
us111
yep,snip them off,be sure to tape up good,should b done.
us111 is offline   Reply With Quote
Old 07-30-2008, 11:02 PM   #4
jrsmith_2010
I like turtles...
sweet, thanks guys
Old 07-31-2008, 07:49 PM   #5
jrsmith_2010
I like turtles...
or i was thinkin maybe a newer 3rd brake light, has anyone done this? is it hard to do?
Old 08-01-2008, 12:27 PM   #6
Captkaos
Captkaos's Avatar
Still will have to separate the wires, but you will need to tap into the brake switch.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 08-01-2008, 01:45 PM   #7
piecesparts
Parts and more parts
piecesparts's Avatar
I took out my cargo light and made it a brake light with the addition of a 1997 Nissan light fixture. Decently shaped and designed light and it fits over the holes and makes the truck look better.
Old 08-01-2008, 06:38 PM   #8
DubDubU
DubDubU's Avatar
My 79 has seperate connectors for the dome and cargo light down by the floor below the cargo light switch.
'79' shortbed
DubDubU is offline   Reply With Quote
Old 08-01-2008, 07:02 PM   #9
jrsmith_2010
I like turtles...
really? like how are they different conectors when there is only one switch for both?
Old 08-01-2008, 08:43 PM   #10
DubDubU
DubDubU's Avatar
I"ll post a pic later this evening, my fingers don't explain things well.
'79' shortbed
Old 08-01-2008, 09:49 PM   #11
DubDubU
DubDubU's Avatar
Hope this helps. The upper connector on left is the dome light and the lower on right is the cargo light. The wires going off to the right behind the seat belt retractor goes up to the dash.
'79' shortbed
Old 08-02-2008, 02:15 AM   #12
jrsmith_2010
I like turtles...
sweet, that will be easy to take out, thanks for the posted pictures!
