07-30-2008, 07:19 PM | #1 |
What's up with my tie-rod hitting the arm?
I dropped the crossmember 1", so do I have to raise and /or move my power steering pump up or back? Thanks
Also, I know I need a different pitman arm, it came with the pump.
Blazer Project |
07-30-2008, 07:31 PM | #2 |
Re: What's up with my tie-rod hitting the arm?
Sorry, here is a pic.
Blazer Project |
08-01-2008, 04:56 PM | #3 |
PROJECT 7DEUCE
Are you saying you sectioned the crossmember?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-01-2008, 05:14 PM | #4 |
yes, 1 inch.
Blazer Project |
08-01-2008, 11:36 PM | #5 |
PROJECT 7DEUCE
I have strong arms but the only issues I had was a little clearance issue with the tie rod hitting the crossmember and the front u-bolt..
08-02-2008, 12:30 AM | #6 |
do you have any pictures?
Blazer Project |
08-02-2008, 02:33 AM | #7 |
PROJECT 7DEUCE
You can see where I ground down the bolt and the front of the crossmember. I am not too worried about the crossmember but I do need to fix the u-bolt... Just break out your grinder and make everything fit..
08-02-2008, 09:23 AM | #8 |
well done. Did you raise the power steering pump?
Blazer Project |
08-03-2008, 08:14 AM | #9 |
08-03-2008, 12:15 PM | #10 |
its just $$$$$
I think he means the box.
It looks like you need to replace that Pitman arm before you start clearancing everything else. |
08-02-2008, 07:15 PM | #11 |
PROJECT 7DEUCE
Nope did not raise the pump or the box...
08-03-2008, 12:15 PM | #12 |
It'd be alot cooler if you did
to keep all the geometry correct you should raise the steering as much as you raised the cross member. If you don' it will bump steer.
