steering gearbox ,what years?
my 67 has a sealed steering gearbox , a powersteering pump with the hoses running to some hydrualic cylinder on the tierod. and of coarse it doesnt work. will a normal powersteering gearbox from a newer truck swap right in? and will my powersteering pump work with it? what year trucks can i pick from and also is there any other parts i need to get along with it?
Re: steering gearbox ,what years?
I used the box off a '75 and it was a straight bolt in. I know the pumps are the same, but I don't know about the lines.
My '69 was manual and I pulled the box and pump off the donor. <edit> '73 to '87 should all be the same.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 Last edited by jimmydean; 08-01-2008 at 11:57 AM. |
![]() Join Date: Jul 2008
Yes I think thats right I took my power off and put a manual steering box off of a 1971 and it bolted in the same holes as my power steering box did (1980) c10
Built chevy tuff! ![]() |
One day...
![]() Join Date: Apr 2008
Ya i know one from a 73 sub will work, it was on my 62 and is now on Joe231's 66
Or you could fix you ram assist power steering. All of the parts are still made. Corvette used the ram assist for a lot of years. There is a FAQ on repair parts and where to get them.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
If Im not mistaken, 67s dont have the bump in the frame to accept the later style powersteering box. Im not sure if the holes will line up either. It can be done but you might want to search on the topic first to see what others have done.
