Old 08-01-2008, 05:42 PM   #1
FRCvette
Going to look at a truck Saturday
What do I need to look for.The truck is a 69 SWB 305 V8 and 3 on the tree.No power steering or brakes.It has been a tennessee truck all its life.I know the 305 is not stock it was originally a 6 cylinder truck.I am pretty excited about the truck but don't want to get burn't on the deal.
FRCvette is offline   Reply With Quote
Old 08-01-2008, 09:27 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Going to look at a truck Saturday
Check all the cab corners,floor,area over the windsheild,and floorboards.Also behind the rear wheelwell and in the cowl.Most of these area can be repaired but you do want to know what you are getting into.Take a small magnet(refrigerator style bussiness card works well) to check for bondo.Take along coveralls and crawl under the truck,surface rust isn't much problem but a frame that has rusted away areas is going to be a problem.
The other thing I would advise is to take along another car guy.Usually someone that is not stoked about the vehicle will see little flaws the buyer doesn't notice in his excitement.Keep in mind that trim pieces add up in cost pretty quick so if it's not there you will be buying it or smoothing it.Pitted chrome usually is cheaper to replace than replate.Read thru the FAQ's a bit and you will find lots of stuff to check out.I usually look one over pretty well then walk away and go eat lunch or something .Then go back and look again so it can hit me or not.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-02-2008, 01:42 AM   #3
mas09ts
mas09ts's Avatar
Also check the cab supports, I didn't check mine when i bought then got it home and seen that they were rusted out and now I'm replacing all four of them.
Mitch
22yrs. Young
1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011
Current Project 68 Gmc "Second Chance"
Go to my 68 GMC Shorty Rebuild Thread
http://67-72chevytrucks.com/vboard/s...39#post6341739
mas09ts is offline   Reply With Quote
Old 08-02-2008, 08:43 AM   #4
Boog
laying low
Boog's Avatar
A matching title.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 08-03-2008, 02:12 PM   #5
FRCvette
Well I went at looked at the truck.Looked great from 10-15 feet away.Cab corners had been patched as well as roof above sunvisors.Drip rail was loaded with filler.Thanks to you guys for telling me where to look.I probably would have bought this truck if I not known where to look.I was really hoping this was the one -guess I will keep looking.Thanks for help.
Old 08-03-2008, 04:11 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
The "filler" in the drip rail is factory applied but you still have to check around it for rust through. If the inner roof panel above the sun visors has been repaired I think I would shy away from it though....
LockDoc
Leon
