Gen3 Engine Swap- Or not?
The 327 fuelie motor in my '65 GMC has seen it's day, and it's obvious that it is tired out when driving my truck around. I'm not sure exactly when it was put in the truck as I've only had my GMC for about 6 months now.
I got the truck not only because of my love for vintage autos (it was love at first sight), but also to tow my 1972 2-horse trailer that I'm currently restoring to match the truck. In considering an engine swap, there are so many options it's overwhelming. I just want a reliable tow vehicle. My brother has suggested a 6.0L gen3 engine; other friends have suggested an older 350 or 454 would do just fine. Gas mileage is a concern, but i hope to improve that a little bit anyway when we swap in an overdrive (3sp auto right now). Any opinions, experiences, or general help regarding my dilemma would be greatly appreciated! Thanks, Sara ![]()
My 1965 GMC 4x4 http://67-72chevytrucks.com/vboard/s...22#post2754022 My brother's 1972 Blazer 5.3 E85/ NV4500 5spd 4x4 Work in Progress http://67-72chevytrucks.com/vboard/s...d.php?t=291482 Last edited by Calitruckgrl1; 08-04-2008 at 03:16 PM. |
283 Drama Queen
![]() Join Date: Dec 2004
Re: Gen3 Engine Swap- Or not?
Sara, I went with the ‘Target Motor’ (350) with my 65’ Chevelle - from having a stock ‘283’ and put an Edelbrock intake and carb and never looked back. I’ve got it hooked to a pumped Powerglide and it’s a stump-puller. Six months on the engine - two oil changes: That’s it. $1600 base price and the top-end stuff from Summit. EVERYTHING else from the ‘283’ bolted right up.
Mac.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
#3 | |
Sara, I guess it really depends on how much you want to spend and how many miles you're going to put on. I'm eventually going GenIII in my suburban because I plan to cruise around BC with it, pulling a small trailer. Thus mileage is pretty important. But if you're only going to go a few thousand miles a year, then what's the diff?
Also, I'm glad you're considering the transmission. An overdrive tranny (stick or auto) will make more of a mileage improvement then the difference between a well tuned carb-350 and a gen3. One thing I can say, I'll bet you'd be happy with the 6.0L gen III once it was done. ![]()
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
I've been interested in this swap and i called a local latemodel auto recycler and they priced me a 5.3l and trans with all acc. and ecm for $1300.00 ,50,000 miles on engine.To me this is the only way to go.It sounds like your going to be putting some miles on the truck with a horse trailer so overdrive would be nice. I believe this swap can be done as reasonable as a 350 /700r4 swap.
350 = 1600 700r4= 650 and up newly rebuilt total = $2250 5.3l and 4l60e = 1300 fuel lines & tank new = 700 custom tune on ecm = 200 and up total = 2200 there are alot of other items to work out motor mounts,wire harness custom or use original ,finishing up the exaust.This engine stock is rated at 295 hp and 325 lb of torque and gets good mileage.good luck Sara hope my ramblings help you decide. |
Jonny
I'm putting a cummins in my 64 panel. I'm thinking it will net me mid 20's fuel milage and still pull 10k lb trailer. I'm setting it up with a3.42 gear and a nv4500 5-spd. guess I really need to start a thread on that here
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR Last edited by sailed2japan; 08-04-2008 at 08:17 PM. |
#7 | |
Custom harness complete from headlites to tails = 1300.00 SS gas tank with internal gm fuel pump = 1000.00 tranny tailshaft to drive a mechanical speedo and the computer = 500 new GM O2 sensers = 250 Etc....etc... etc.. this time for my 66 I chose a vortec again, but with a carb and a non computer 700R4... could not be happier runs like a dream been three years and I would drive it anywhere.[IMG] ![]() don't get me wrong, I loved the fuel injection and would love a LS, but don't think that I can do it on the cheap
http://www.picturetrail.com/fregon |
#8 | |
Jonny
I agree with you on spending the $ on a good setup rather than spending the cash on low-quality products or even getting something for cheap that isn't really what you want to save a few bucks. And by the looks of the frame, that's gonna be a sweeet set-up.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR Last edited by sailed2japan; 08-06-2008 at 11:55 PM. |
you are right, suicide and I agree with you completely, but keep in mind that a TPI setup is much simplier than a OBD2 setup and the LS engine/trans.
Your setup looks great ![]()
Council of the Elders
If a modern EFI engine with overdrive tranny doesn't violate you sense of vintageness, AND you have the resources ($ and mechanical expertise) to make it happen, that may be the way to go. It would require a new fuel system, probably including relocated fuel tank... so there are technical challenges. FYI you can also put fuel injection on a gen I small block by using Tuned Port parts that came on camaros and corvettes from 85-92. If you just want to keep it simple and inexpensive the 350 crate motor is surely your calling. Good luck.
www.chevythunder.com
66 C-10 Stepside 350 Tuned Port Injection Tremec TKO-600 Truck Pictures: http://community.webshots.com/user/billydonn Truck Video: http://good-times.webshots.com/video...ost=good-times Last edited by billydonn; 08-04-2008 at 11:03 PM. |
60-66 Nut
If it is within your budget and the conversion is within your skill level (or your brother's or someone who can help you) then I would go with a Gen 3. A 5.3 should have enough power for a 2 horse trailer and yet get decent mileage. IMO this swap would also add value to your truck.
The 6.0 would have more power, but I've heard they aren't the best for gas mileage.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-05-2008 at 12:45 AM. |
Junior Member
My vote is for the Gen III swap, although I'm partial. I aquired my 5.3/ 4l60e with 5k miles and all acc, wiring and computer for 1k, I had to pull it.
Mounting the drive train is the easy part. A set of engine mount adapters from advance adapters, move the auto trans cross member back and have the drive shaft shortened. Thats all there it to physical mounting. I relocated the gas tank to the rear and spent about 250$ doing it. If you or someone you know is good with wiring, then modifying the gen III wiring harness is pretty easy, there's a ton of info on the how. I went with a stand alone computer. 200$ for a upgraded tune is needed for the stock computer. There is not really to much to it. If your trailor is something that could be pulled behinde a suburban then a 5.3 would suffice with a set of 3.73 gears in the rear end. Since doing this swap I will never go back and run a old school 350, My 5.3 runs too damn good!!!! Graham
A good friend will come bail you out of jail, but a true friend will be sitting next to you saying, "That was ****ing awesome." |
![]() Join Date: Mar 2008
gen1 crate 290hp is an easypeazy all click option...factory new, but greenMileage ain't really its forte.
Weekend wrench Feb. ![]() Mar. ![]() April ![]() May ![]()
Matt '65 LWB Fleetside '63 SWB Fleetside |
#15 |
Just do it!
