Old 08-04-2008, 03:09 PM   #1
BartK10
Manual Throttle
My truck was originally equipped with a manual throttle on the dash under the wiper knob. The throttle still works, but it operates very hard and when I try to use it, I end up pulling off the knob and stripping the set screw. Does anyone know how to make it operate more freely?
BartK10 is offline   Reply With Quote
Old 08-04-2008, 03:18 PM   #2
Riveted1
Tasty Cakes!
Riveted1's Avatar
Re: Manual Throttle
Lubricate it?
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 08-04-2008, 03:24 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
Re: Manual Throttle
It is a screw mechanism and you turn it. Counter clockwise moves it out (higher rpms), clockwise move it in (lower rpms). I usually operate mine by pressing the gas pedal to approximately where I want the rpms then turning the hand throttle far enough to hold it there. The I fine tune accordingly. Mine is adjusted so that when all the way in, it is tight against the linkage but does not impede it's forward or backward movement. In this way you don't have to turn it too many revolutions to get it to "set".
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 08-04-2008, 03:31 PM   #4
BartK10
Re: Manual Throttle
Thanks for the help. Never tried screwing it out or in, just assumed it was a push/pull knob. I suppose I ruined it now though. LOL, just my luck.
Old 08-04-2008, 03:20 PM   #5
Sammy
Re: Manual Throttle
PB Blaster
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-04-2008, 03:54 PM   #6
Yukon Jack
Yukon Jack's Avatar
Re: Manual Throttle
Hmm, the factory manual throttle that is on my 69 K20 is a push pull kind of one.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 08-04-2008, 04:11 PM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
Re: Manual Throttle
The one I use is a 71/72 and attaches to the cable linkage at the pedal, not to the rod outside the firewall.
Old 08-04-2008, 04:46 PM   #8
BartK10
Re: Manual Throttle
Mine attaches to the linkage at the pedal as well.
Old 08-04-2008, 05:14 PM   #9
Yukon Jack
Yukon Jack's Avatar
Re: Manual Throttle
I see, guess that makes sense given the different way that the pedal works.
