Old 08-10-2008, 08:15 PM   #1
1971 K10 shortbox
Convert an auto tilt to a manual tilt
Is it possible to convert an auto tilt to a manual tilt?
Does anyone have advice or instructions on the process?
1971 Chevy SWB 4x4
1971 Chevy LWB
2003 Duramax
1971 K10 shortbox is offline   Reply With Quote
Old 08-10-2008, 08:18 PM   #2
msgross
msgross's Avatar
Re: Convert an auto tilt to a manual tilt
sure, grind off the parts and add some JB weld.. then smooth it, add a little filler, sand and paint.
Or spend $400+ for a new tilt...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-10-2008, 08:22 PM   #3
JimKshortstep4x4
If you are thinking of a tilt with a shifter on it for a (3) speed then probably not. Converting it to a column for the manual floor shift can be done.
Which one are you thinking of wanting to do?
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 08-10-2008, 08:25 PM   #4
Andy4639
Old member
Andy4639's Avatar
Here is a manual tilt for sale. It's not mine I'm just using the pictures that others posted.
Here are some pictures of a auto tilt.
See the differances in them. The top is a easy fix body filler or weld it up and smooth it out. The bottom can be left as is or cut it all off.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-10-2008, 08:42 PM   #5
1971 K10 shortbox
Floor shift for a 4 speed manual.
1971 Chevy SWB 4x4
1971 Chevy LWB
2003 Duramax
Old 08-10-2008, 08:44 PM   #6
1971 K10 shortbox
I see what your sayin Andy, is it really that easy?
1971 Chevy SWB 4x4
1971 Chevy LWB
2003 Duramax
Old 08-10-2008, 08:53 PM   #7
Andy4639
Old member
Andy4639's Avatar
YES
You don't even have to cut the bottom part off if you don't want to. I bet you could find someone who would trade you for it if you wanted to. The top part could be fixed very easy if you can weld or have someone do it for you are just leave it alone in cae you ever went back to a Auto.
I just took mine out and painted it last week.
It is a manual shift also.
Old 08-10-2008, 09:25 PM   #8
msgross
msgross's Avatar
There was a website that made a collar for it, not sure that it would look that good though
The Garage:
Old 08-10-2008, 10:47 PM   #9
Andy4639
Old member
Andy4639's Avatar
Check this out on doing a tilt.
http://www.customclassictrucks.com/t...c10/index.html
Found this on E bay.
Doing a tilt wheel is cheap.
http://cgi.ebay.com/ebaymotors/67-72...spagenameZWDVW
Old 08-10-2008, 11:05 PM   #10
1971 K10 shortbox
I was kinda thinking the same thing Andy, see I current dont have a tilt column of any kind. It seems that it is easier to find an auto tilt vs. the floor shift tilt, so thats when I started looking into modifying an auto tilt.
1971 Chevy SWB 4x4
1971 Chevy LWB
2003 Duramax
Old 08-10-2008, 11:10 PM   #11
Andy4639
Old member
Andy4639's Avatar
I understand completely. Get a 78 van tilt and your set. You will have the bigger diameter shaft plus they are cheap compared to a 67-72 tilt. Follow the link I posted and your good to go.
Old 08-10-2008, 11:50 PM   #12
1971 K10 shortbox
See thats what I love about this site, we all have that same passion about these old trucks. The way everyone interacts with each other as if they were all old friends.
1971 Chevy SWB 4x4
1971 Chevy LWB
2003 Duramax
Old 08-11-2008, 01:16 AM   #13
Andy4639
Old member
Andy4639's Avatar
That's what it's all about. Helping each other! Not how much money I can make!
Old 08-11-2008, 08:08 AM   #14
msgross
msgross's Avatar
I am using a van tilt and modifying it...
I just got luck enough to find a board member selling all the needed parts from a manual tilt to convert it.
The Garage:
Old 08-11-2008, 09:02 AM   #15
rscam
I used a van tilt from a middle 70's. Easy install. Hardest part was the pins in the lower shaft had to be taken out to shorten it.
rscam is offline   Reply With Quote
Old 08-11-2008, 12:25 PM   #16
19stepSide72
wanna be 67
19stepSide72's Avatar
what a great idea for someone to do .......put in the FAQ a how to convert a auto tilt to a manual tilt!!
19stepSide72 is offline   Reply With Quote
Old 12-30-2008, 01:24 PM   #17
msgross
msgross's Avatar
ok, started doing this today... of course I didn't take pictures but will bactrack and document it a little better....
The Garage:
