08-11-2008, 11:32 PM | #1 |
wood bed
I have a new wood bed in my truck. The varnish is already coming off.
What is the best stuff to re-finish it with? I want it looking food for a fall sale |
08-12-2008, 09:50 AM | #2 |
Retired Air Force Veteran
Re: wood bed
I've seen many board members suggest using Spar Varnish.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
08-12-2008, 04:01 PM | #3 |
Re: wood bed
use spar urethane its made for wood on boats so it will deffinately hold up.
08-12-2008, 04:18 PM | #4 |
Re: wood bed
Spar varnish works well, but if you do it right polyurethane will work well also. My father in law finished bowling alley lanes for years and suggested the following when I did mine. Quality poly, brushing in only 1 direction, wait until out side is dry (flash dry it will still be wet on the interior. Use a wool bonnet on your buffer to turn the molecules of the poly.this will cause the poly to cross bond, allow to finish drying, wet sand with 600 grit paper and add another coat using same process until you have the coverage you want, I went 8 coats using this method. This was on the top only, on the bottom sides and ends I mixed linseed oil into the poly, stirring well. The linseed oil acts as a carrier for the poly pulling it into the wood. Your wood will get significantly heavier, but you will nothave to worry about rot or peeling problems. You will get a furniture like finish on the top and the rest will be like a rock. This is what the finished product looks like.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
08-13-2008, 10:19 AM | #5 |
Re: wood bed
Thanks for the options
