Old 08-12-2008, 12:11 AM   #1
hensonjd
I am proud of myself
Well today i got all of my parts in for my first project. I had ordered a new hei distribute, 3 and 5 inch drop springs, and a power brake kit. Well today i decided to install my coils and i started at about one took about a 2 hour brake and finished at 11. I am 18 and it was my first real mechanical thing to do on a an old tuck. I have been a tractor mech for years but i just got started with the classic restos. When i got started i didnt know how big of a job i had gotten into but i somehow worked through it. My dad just sat back ad watched me struggle i ges he wants me to learn it on my own like he did. I just wanted yall to know it worked out for me and i had fun. Just wondering if anyof yall could give me some pointers on installing my distributer and brake booster kits. Thanks for any guidance on the subject.
hensonjd is offline   Reply With Quote
Old 08-12-2008, 12:30 AM   #2
El Jay
Gone to greener pastures
Re: I am proud of myself
I'm sure if it looked like you going to get into trouble Dad would have stopped you.
As for the distributor; pull the #1 spark plug and stick your finger in the empty spark plug hole. Then have somebody "bump" the starter until the compression "blows" your finger out of the spark plug hole. Don't worry, it's painless.
Manually roll the engine forward, or backward, until the timing mark on the harmonic balancer is pointed at "0 degrees".
Pull the cap off the distributer and mentally make a note in your head where the rotor is pointing in relationship to the intake manifold; and the relative location of the distributor housing.
Pull the distributor clamp and lift the distributor out.
Note: The distributor has helically cut gears (I think that's the term) and it will rotate backwards upon removal. Keep a mental note of this also, as to how far it rotates.
Take the new distributor, point the rotor to about where the old one pointed when it came out and drop it into the hole.
You may have to do this a couple of times to get the oil pump drive to line up.
Once you have the new distributor tight against the intake manifold, clamp it loosely.
Put on the new cap and install the wires and it should fire right up.
This whole thing sounds a bunch more complicated than it is, trust me.
Hopefully, others will chime in and maybe give you a couple of short cuts.
Oh yeah, don't forget to install a new distributor gasket under the distributor flange, unless you like oil leaks.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 08-12-2008, 12:39 AM   #3
hensonjd
Yea i dont need any more oil leaks. It already seems to be leaking somewhere around the intake. Do i need to get new plug wires to hand he hei system and if so what size and brand do you prefer?
Old 08-12-2008, 01:09 AM   #4
El Jay
Personally,I use either CarQuest (but the store owner is admittedly a friend of mine) because of the lifetime warranty, or NAPA Beldon wires, for the same reason.
Except for things like oil, filters, and chemicals, etc; I avoid places like Kragens, Schucks, Pep Boys, Autozone.
I won't cut off my nose to spite my face. If it's Sun. evening and nobody else is still open, I'll go to the chain places, just so I won't have to wait until morning to get parts.
But that's just me and my .02.
Old 08-12-2008, 04:35 AM   #5
cdowns
cdowns's Avatar
if replacing a points distributor with an hei distributer you need to run a new power supply wire as the original wiring in the truck is a resistor wire and will fry the dizzy in short order
also you should be taking the truck in to have an alignment done so that you'll get max life out of your tires with the new geometry in the front end with the lower springs
Old 08-12-2008, 04:51 AM   #6
Curbstone Mech
Active Member
JD
You deserve to be proud. These trucks are a grear American hobby. There is nothing wrong with a little "bragging exercise" after an accomplishment. Good luck on the rest of your project
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
Old 08-12-2008, 12:08 PM   #7
hensonjd
After reading through the old post i think that i have gathered that you need to remove the resistor wire and run a new wire between the distributer and something to ensure that it turns offf. Could Someone elaborate on these things? Im knida slow and need the play by play. thanks
Old 08-12-2008, 02:31 PM   #8
Luvlegs
Luvlegs's Avatar
you'll need a 12v power supply to the dizzy (keyed power) - also regap your plugs to about .045.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 08-12-2008, 03:10 PM   #9
70rs/ss
70rs/ss's Avatar
I use a blade plug from Napa and replace the whole wire from the main firwall plug. Locate the wire to the points dist and that is a whitish wire with a fiberglass sheath. Trace it to the firewall plug, use a 3/8 or 5/16 socket to remove the bolt in the center of the plug. Pull the plug out and with a pair of needle nose pliers, squeeze the blade horizontally ( [----] ) the [ and ] are the best I could do to "look" like the pliers! Squeeze the blade towards the base of the plug looking down on all of the blades. The wire will pull out from the back of the plug, NAPA sells the exact blade type plugs, carry the old blade in with you and they'll be able to match it up. Use a new 10-12 guage wire and run it to the HEI, NAPA also sells the correct OE hei plug as well (you do not 100% need it, but it helps to keep the wire from unplugging as you drive!). the new blade slides in from the back and the spliced spade "clips" it into a locked position, put the firewall plug back into the firewall and reinstall the bolt, now you have a 12v switched power wire to the hei!! I'll let someone else help you o the brake MC/booster as my fingers are tired!!
Congrats and good luck, I learned my skills under the watchfull eye of my dad and brother over the years and from doing it myself, reading, listening and asking, the best way in my book, I know what I know because I have done it, and so do you now!!
70rs/ss is offline   Reply With Quote
Old 08-12-2008, 06:44 PM   #10
hensonjd
I got the new brake pads on and put the front wheels back on and lowered it to the ground and have discovered that the back end is sitting lower then the front. Is this normal after a 3 and 5 inch drop? this realy bothers me what is the deal?
