11-14-2002, 03:45 PM | #1 |
Spank 'em if you got 'em!
"Ignitor" coil issue
I just ordered my Pertronix Ignitor. Think I got a good price. Anyway, specs say I need a 40k volt coil for best results after the conversion. Does anyone know what a stock coil puts out on a '71? Should I go ahead and upgrade my coil?
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
11-14-2002, 05:12 PM | #2 |
Fabricate till you "puke"
I picked up the coil to go with the ignitor, it was only $30......i dont know if I really needed it, but what the heck......1 more new component
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
11-14-2002, 05:24 PM | #3 |
I guess I found the answer to my own question without looking for it. I was on another web site looking at headers and came across an article about Ignitors. Said OEM ignition pulls ~25k volts, but just putting on the ignitor with OEM coil will swing 35k volts. Just have to see what happens I guess. Anything is better than points!
11-14-2002, 07:41 PM | #4 |
Progress = 0%
I've got a "stock" coil in my '57 and it works just fine with the Ignitor. Not sure if a stronger coil would make any difference in performance.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
11-14-2002, 09:40 PM | #5 |
Ingnitor II
I have the newest version of Ingnitor systemII Including the Coil
for 95.00 plus shipping. The reason you need the coil Is because It's a low resistance coil .06 ohms the stock would eventally decrease the proformance of the system @ higher RPM as well as the life of the system........
71 C10 LWB With Edelbrock 7101& 1406 Carb Accel HEI Blue Print Accel 8.8 Wires Soon to have possi & 186 Camel hump heads Dropped 2-1/2F&4R Dynomax Headers Duals Flowtech Aftburners Tonneau Cover Frm 89 F150 79 Monte C |
