08-15-2008, 11:36 PM | #1 |
mild 454
hey guys, i'm debating on building a mild 454 to go into the 85 chevy. its got a smallblock 400 in it now that i've told ya'll about. and my plans for it.
what do ya'll think of the idea of instead of doing all that to the 400 just building a mild 454 and dropping in there? |
08-16-2008, 12:46 PM | #2 |
Re: mild 454
It would run like hell thats for sure but gonna cost more for parts
Built chevy tuff! |
08-16-2008, 04:55 PM | #3 |
Re: mild 454
I just built a sbc 400 for a friend that runs 11.80's on pump gas in a 71 swb. The only thing expensive was the heads.
08-16-2008, 05:09 PM | #4 | |
PITbut
Re: mild 454
08-16-2008, 06:38 PM | #5 |
Re: mild 454
BBC are more money to build, but not a sure huge difference. Plus BBC under hoods are instant respect because of so many SBC normally found.
I like all GM V8's, but BBC are my bread and butter. I'd say go for it.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
08-16-2008, 07:51 PM | #6 |
Re: mild 454
yeah i think it would be cool to have that wow factor too of just saying i have a bbc under the hood lol. street credit lol
now what tranny should i go with behind it? th400? |
08-16-2008, 08:31 PM | #7 |
Re: mild 454
Depends on how wild.
I ran a mild TH350 behind my 550+HP 454.
08-16-2008, 08:48 PM | #8 |
Re: mild 454
well it'll be a nicely built th350 if it'll hold up.....it'll have a manual valvbody and brake. looking for around 550-600 out of the 454. th350 should be able to be built to hold that huh?
08-16-2008, 08:54 PM | #9 |
Re: mild 454
If you are going to run a brake, I'd just go with the TH400. Transbrakes are pretty hard on the trans. Better to build one tranny once and have the piece of mind.
08-16-2008, 09:14 PM | #10 |
Re: mild 454
what if i didn't go with a brake......i'm going to be running the foot brake class anyways
08-16-2008, 11:13 PM | #11 |
Re: mild 454
A mild 454 won't make 550-600hp.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
08-18-2008, 12:52 AM | #12 |
PITbut
Re: mild 454
08-18-2008, 11:50 PM | #13 |
Navy Radioman Veteran
Re: mild 454
I just finished installing a mild 454 into my '87 SWB.
Here's what it looked like recently; All the info about the build is in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=279281 I don't think it's as BADAZZ as that Z but it's pretty nasty. It's around 450 hp / 500 ft. lbs at the flywheel according to software. Kenny
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside - SOLD 2005 Chevrolet Tahoe Z71 Last edited by 87Lowrider; 08-18-2008 at 11:51 PM. |
08-16-2008, 11:38 PM | #14 |
Re: mild 454
ok well what i mean by mild is basically a head/cam/intake 454
nice dominator carb of some sort i dont really know much when building a big block if i do it then it'll be a learning experience for sure. |
08-17-2008, 11:28 AM | #15 | |
Re: mild 454
Building a decent street/strip 454 or 496 is easy enough. GM iron oval port heads with 2.19/1.88 valves and a mild port job on top a 9.5:1 compression 454/496 and decent size cam (like Lunati Voodoo series) and you'll have tons of torque and more horsepower than your tires can handle. 12's are pretty easy at that point. Don't get wrapped up in the 'bigger is better' problem that lots of folks end up doing. Things like single plain intakes, huge cfm carbs, 2"+ primary headers, 3500+ stall converters, manual valve body trannys, and 4.56+ gears are not needed on anything but the more serious race car/trucks.
08-17-2008, 02:38 AM | #16 |
Re: mild 454
What's yhour budget?
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
08-17-2008, 11:31 AM | #17 |
Re: mild 454
Here is a good example, I ran this 454 in my little Datsun Z car:
Bottom End: -454, 4 Bolt Block w/ARP Main Studs -Bored to 4.280" (0.030" overbore), Honed w/Torque plate -Stock 454, 4.00" Stroke Cast Iron Crankshaft -Stock Big Block Chevy I-Beam 'TRUCK' Rods w/3/8" ARP Wave-Loc Bolts -TRW/Speed-Pro L2465F Forged Pistons (25.7cc dome volume) appox 9.5:1 Compression w/119cc Heads -GM .020" Steel Shim Head Gaskets (Copper-Coated, pre-torqued) -ARP Head Bolts Up Top: -Chevrolet '049' Large Oval Port Heads, 2.19/1.88" S/S Valves, Pocket Ported -UltraDyne Designed, Lunati Ground 402A2 Solid Flat Tappet Cam: .550"/.570", 272/282 adv dur, 238/248 dur@0.050", 112 LSA and 4* advance ground in -EDM Oil Pin 0.021" Hole Solid Lifters -3/8" Chrome-Moly Racing Pushrods -1.7:1 Crower Stainless Endoro Roller Rockers -Edelbrock Performer RPM 'Air Gap' Intake Manifold -Holley 830HP Carb -HEI Billet Distributor Tranny/Exhaust: -TH350 Tranny w/Trans-Go Shift Kit -ATI Streetmaster 11" 2500 Stall Converter -Nissan R200 VLSD w/3.45:1 gear ratio -Ground Control Adjustable Coilover Conversion -Tokico Struts -Custom Block Hugger Headers, 2" primaries, 3.5" collectors -Dual 3" exhaust, Dynomax UltraFlo Race Magnum round mufflers
08-17-2008, 03:08 PM | #18 |
Re: mild 454
PICS!!!!!!!!!!!!!!!!!!!!!
(sorry for the hijack, but I need to see this)
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
08-17-2008, 03:44 PM | #19 |
Dr. Frankenstein
Re: mild 454
X2 on datsun pics(my friends 383ci is a MONSTER)the THING must rule the streets
I Wanna Go Fast!! |
08-17-2008, 12:08 PM | #20 |
Re: mild 454
well as far as budget goes, i'm not going to be throwing his together in a few months. i'll run this 406 that is in the truck while i'm building the 454. so i lots of time to be able to piece the engine togither. if it takes me 6 months to get a nice 454 built then it takes me 6 months. i'm willing to wait to make sure i get the right parts and good parts to get it together.
and i dont even have the 454 yet. i'm still trying to scroug one of those up right now. |
08-17-2008, 01:40 PM | #21 | |
Re: mild 454
Too bad you aren't closer.
08-17-2008, 04:09 PM | #22 |
Re: mild 454
bummer lol
08-17-2008, 04:59 PM | #23 |
Re: mild 454
08-18-2008, 12:31 AM | #24 |
Re: mild 454
Starting with what you want it in finacially will give a better understanding of what motor/setup to run. That's just me though..
08-19-2008, 12:18 AM | #25 |
Built 4 Speed
Re: mild 454
i picked up a 85 4 bolt 454 turn key for $500. pretty high miles but im redoing everything and so far my block has checked out.
if you got a motor in the truck and got time just dont rush it and find a good deal and have it rebuilt with some good light Balanced internals. along with you cam intake and Carb, "the toilet bowl isnt nessicary". i think you will be completely satisfied with results. Big blocks are about 40% more expensive for all parts across the board. compared to sbc's
1969 C/10 Short Box: 496/T-56 in worx. "To Be Old And Wise, First You Must Be Young And Stupid" |
