08-20-2008, 03:45 PM | #1 |
gear swap calculator needed.
I'm thinking about changing the gears in my rear end. Does anyone know of a calculator that I can use to guestimate my engine RPM and freeway speeds?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
08-20-2008, 03:52 PM | #2 |
Re: gear swap calculator needed.
This one I like and use a lot.http://www.grimmjeeper.com/gears.html
It is for 4 wheel drive but you can put in any transfercase and just look at the high range numbers for 2 wheel drive. You can put in your current set up and what you want to change to and it shows you both so you can do a side by side comparison. it also has most transmissions available for automatic gear ratio selection or you can enter your own numbers. It also lets you compare different tire sizes along with gear swaps. Brent |
08-20-2008, 06:12 PM | #3 |
The LuvShack Garage
Sheesh, that one is nice, but too much data, got anything for lazy arses?
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
08-20-2008, 07:02 PM | #4 |
There's some simple ones here http://www.ringpinion.com/Calculators.aspx
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
08-20-2008, 07:06 PM | #5 |
member #16
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
08-21-2008, 07:36 PM | #6 |
sharp as a marble
www.classicchevy5speeds.com
they have an rpm calculator for lazy people. ME!! |
