Old 08-23-2008, 09:28 PM   #1
ChadBice
10 Bolt v. 12 Bolt
I'm sure this topic has been covered a million times, but my poor searching techniques haven't been able to find an answer to my question.
I have a 1971, C10 with leaf springs and a 10 bolt rear end. The engine is a 350, slightly warmed. It currently has a TH400, but I'm debating changing it to a 700R4. With that in mind, is there any reason (aside from the fact that a 12 bolt is much more durable) that I should change the rear end if the one I have is good? Some people have said that the 10 bolt is too weak for my motor. Can that be true? That's what came from the factory. If I do change it, what can be used as a donor? Thanks!
Chad
'71 Chevy SWB
ChadBice is offline   Reply With Quote
Old 08-23-2008, 09:52 PM   #2
Gray Ghost
Gray Ghost's Avatar
Re: 10 Bolt v. 12 Bolt
I had a 10 bolt behind a 350 hp SS El Camino....it held fine for years. I doubt you'd have any trouble with it but you might have it checked anyway just in case. Personally I see no reason to change it if the gears are good.
Kelly
'05 GMC Sierra SLE Z71
Bone stock except for new bed rail caps.
Gray Ghost is offline   Reply With Quote
Old 08-23-2008, 10:02 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I'm wondering who went through the trouble of putting a weak axle in your truck.
They never came with 10 bolt rears
Old 08-23-2008, 10:20 PM   #4
redhead69
fugedaboutit
redhead69's Avatar
Theres a few different 10 bolts.. some would hold up fine like the 8.5 and 8.2, but if you have the 7.2 or 7.5 ring gear Id be a little leary.
Heres a link to help you
http://www.maliburacing.com/rearend_guide.html
Currently truckless
redhead69 is offline   Reply With Quote
Old 08-23-2008, 10:22 PM   #5
msgross
msgross's Avatar
do you have a pic of the axle?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-24-2008, 04:55 PM   #6
ChadBice
Here's a photo of the rear end.
Chad
'71 Chevy SWB
Old 08-24-2008, 04:57 PM   #7
msgross
msgross's Avatar
yep, basic chevy 10-bolt. Don't know the ring size though.
I say run it till it breaks... why fix what's working.
If you decide that you don't like the gearing then keep your eye out for a 12 bolt posi unit...may pay $300-400 for a decent one.
I sold an open 12 bolt for $50 cause I was tired of hauling it around.
The Garage:
Old 08-24-2008, 07:01 PM   #8
Mike C
Mike C's Avatar
Looks like an 8.5. See the ears below the cover? Ring gear diameter is close enough to the 12 bolt to not make a difference. The pinion diameter is larger than the 12 truck (same as 12 car) The ring gear bolts are reverse threaded and larger in diameter than the 12 bolts, so that's a push. Only short coming is 28 spline axles if the rear is pre 88. Later model 8.5's are every bit equal to a 12 bolt truck.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
