08-25-2008, 10:28 AM | #1 |
Greasemonkey
closeout centerline smoothie help
hey guys i asked this quesition in another thread but i am concidering doing
18/20 20/20 20/22 will any of the wheel offered on closeout work for any of these combinations. I am currently deployed so i cant measure for offset and was wondering if you guys could help me out. here is the link http://centerlinewheels.com/wheel_de...olt&data=6-5.5
1970 cst-10 longbed speed My Baby http://67-72chevytrucks.com/vboard/s...=1#post3113923 |
08-25-2008, 12:46 PM | #2 |
Greasemonkey
Re: closeout centerline smoothie help
would a 5.5" backspacing work on the back and a 5" on the front?
08-25-2008, 12:58 PM | #3 |
Nothing to see here.....
5.5 on the back may be cutting it a bit close. for instance I was about 1" from the bed fender buckets with 8" wide rims and a 4" backspace. you can put some 1" adapters on the rear and it should be fine.
as for the front, I'm thinking the same thing. you may run into a bit of a lock to lock clearance issue, but a 3/4" spacer should help there as well. hopefully someone with big rollers can chime in here with real world experience, but it has been done before. I forgot who it was, but someone on here even had those exact rims and a project truck. and I like them ALOT!!!
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
08-25-2008, 03:04 PM | #4 |
Greasemonkey
ok lets say i ordered a set of rims at full price with the perfect offset.
what offset should i get. 18s and 20s and also 20/20
08-25-2008, 03:30 PM | #5 |
Greasemonkey
more specificaly
20x9.5 rear 20x8 front
1970 cst-10 longbed speed My Baby http://67-72chevytrucks.com/vboard/s...=1#post3113923 Last edited by powerline84; 08-25-2008 at 04:24 PM. |
08-25-2008, 05:22 PM | #6 |
You need to figure out if you have the narrower or wide rearend. I have the the narrow rear, 4.5 backspacing on 10 inch rim and have very little room on the inside and the tire lines up with the outer fender lip on the outside.
BTW, the narrow rearend is .75 inches per side, 1.5 total narrower than the later rears. I think 70 was the switch over year so you might have either.
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
09-02-2008, 09:33 PM | #7 |
i have the centerline zooms in 20 and 22 20 are 8.5 with back space of 5.5 22 are 9.5 with back space of 4 3/4 my truck is bagged and body dropped i am running stock rear end the truck is a short wide
09-15-2008, 12:11 PM | #8 |
Greasemonkey
ok so i think i am going to order these
20x8.5 5.4" at $169.00 18x8 5.0" at 199.00 These should fit with spacers right? 1 inch rear and 3/4 front Anybody clarfiy? At this price i would love to make them work also anybody have these on there trucks please post pics and i would appreciate it.
09-15-2008, 12:44 PM | #9 |
Greasemonkey
ok well i ordered them i am going to make them work cause they looke bad ass.
now i just need help with weel spacing and tire size i was going to with 255/50 front and 275/55 on the origional 18s so now that i have a 20in the rear what size rear tire should i run. i want the heights to be the same as the origional tires.
09-15-2008, 12:59 PM | #10 |
Its Topless Season!!!!
09-15-2008, 04:56 PM | #11 |
Greasemonkey
thanks
i went with 275/45 and 255/45s to keep that raked look what do guys think i should go with on spacers half inch on each or 1 inch on rear and half or 3/4 on front /
