08-25-2008, 11:15 PM | #1 |
my little 305 with nitrous
so i dont know if you all remember or not but a few months ago i made a thread about how upset i was with the results of my 5.3 on the juice. since i finished up my 358 build i figured i would first see what the bone stock internals of my 305 would take. well i was out and about all night and i was amazed at how tough this little motor is even on a 150 shot all night it was like it was begging for more. anyways i just thought i would let any of you stuck with a 305 in your car know there is hope out there. lol. i have some videos i will be posting tomorrow.
anyways i will keep you all updated i'll be racing it at the track this weekend and see if she is really as fast as my butt dyno says it is. mods are as follows: 1986 chevy c10 long bed 305 ci edelbrock 600 edelbrock performer rpm nap dizzy hooker headers 2.5 inch w/40 series 150 shot powerplate system
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm MMA RECORD 24-5 |
08-28-2008, 12:02 PM | #2 |
Re: my little 305 with nitrous
Let us know what it runs.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
08-29-2008, 12:14 AM | #3 |
i will i'm going to thunder valley on sat to see what it is for sure. i'm beating people who claim 14's but its from a role.
i wish my solenoids wernt so small and i could push a bigger shot
08-29-2008, 05:26 PM | #4 |
Pullin' the pin and waitin'?! I am surprized how a motor that we don't care about lasts, but one built to the hilt grenades when it shouldn't! If it holds together I'd bet as long as you do not lean it out it'll hold more N2O, than the 150. Nitrous is safe as long as the RPM is good, fuel pressure and timing, it's when one of those three things isn't right, that parts flee the engine!
08-30-2008, 02:38 AM | #5 |
Ok.. I'll start the ET and MPH guess..
305 on 150 shot N20.. 12.38 @ 112.4
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
09-03-2008, 08:00 AM | #6 | |
so the power shot (small solenoid) are rated at 150hp. is that at the wheels or at the motor ??
09-03-2008, 05:40 PM | #7 |
waiting to hear
09-03-2008, 07:10 PM | #8 |
14.20 at 96mph is my guess.
09-03-2008, 08:44 PM | #9 |
13.3 at 103mph
08-30-2008, 10:36 AM | #10 |
13.8 @ 104
08-31-2008, 03:10 AM | #11 |
mini truck racer
82/91 would test it out for sure . Better yet 82/82 .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 08-31-2008 at 03:14 AM. |
08-31-2008, 12:49 PM | #12 |
Updates?
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
08-31-2008, 07:00 PM | #13 |
Machinist
WELL??????????? "BUTT DYNOS" are cool
08-31-2008, 07:52 PM | #14 |
What that little motor run?? Did it blow? Come on.. The suspense is killing us!!!
09-02-2008, 08:30 AM | #15 |
well i went to the track on sunday and i didnt pass tech inspection. old paranoid farts. i guess they didnt trust my ratchet strapped bottle in the back of my truck .
so i will be racing on the 12th of sept but i need the following: steel fuel lines mounted bottle brackets. battery tie down helmet
09-03-2008, 11:04 PM | #16 |
mini truck racer
steel fuel lines
mounted bottle brackets. battery tie down helmet I think the list should be reversed . 1. Helmet AUTOMATIC 2. BAtery tie down Very nessesary 3. Mounted bottle brackets - See extra full bottles ratchet strapped in ten-5 cars all the time for extra weight , but should be mounted propery . Imagine it flying around in a wreck . 4. Steel fuel lines ? - push lock is allowed up to 12" here . You must have a roll of the cheap stuff , or they didn't like you . Make sure we get an update . My guess is if the timing is pulle dcorrectly and the fuel pressure is constant with the plugs correct , we will all be surprised . Hotrod magazine put 400 on a junkyard 305 and it took all of it till the blippped it and it detonated and it still didn't completely destroy it .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 Last edited by hotrod 80; 09-09-2008 at 11:50 AM. |
09-02-2008, 01:26 PM | #17 |
Well, if an NO2 bottle fell out of the bed going down the strip, it might cause some issues, so safety is a good thing! The steel line is another one, only so much rubber line is allowed. In all you'll be better off for the changes and the brain bucket will keep your mellon purty in case of an accident!
09-03-2008, 10:39 PM | #18 |
15@106>>15 parts of engine at 106mph out the exhaust. LOL
Sounds like fun, I allways wanted to see how much nitrous or boost I could shove down a engine I didn't care about. |
09-06-2008, 01:56 AM | #19 |
Make sure you are on good tires and spray it as soon as you get to 3,200 rpm (I'm assuming a stock verter here)..
09-11-2008, 01:38 AM | #20 |
driving is in my blood
High 14's to low 15's with the spray.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
09-11-2008, 02:08 AM | #21 |
BAD BOW-Silverado XST
It should do 14's easily. I had a 305 pushing high 16's bone stock. That 305 would not die. 13's if you get traction and NOS through the entire run.
09-11-2008, 04:16 AM | #22 |
mini truck racer
13.89
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
