Old 08-28-2008, 01:07 PM   #1
Rooster's 67
Rooster's 67's Avatar
need some help/info please, 3/4 ton disc conversion
I got a friend that we are going to convert his front suspension to discs, but he wants to do it on the cheap. it has the 8 on 6.5 bolt pattern, what donor vehicle do we need to keep the 8 on 6.5's and go to discs?
3/4 or 1 ton components?
I am believing but am not sure that we can use the 73-87 1 ton control arms, spindles,rotors and calipers since they have the 8 on 6.5 pattern.
Forgive me if this has been covered as my searches found only 1/2 ton conversions which i know well.
Thanks in advance
Spence
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 08-28-2008, 02:52 PM   #2
mnky30
mnky30's Avatar
Re: need some help/info please, 3/4 ton disc conversion
i took a x-member from wheel to wheel out of a 80 3/4 ton truck and bolted it in my 60 1/2 ton frame all you have to do is drill a couple of new holes in the frame to make it work.hope that helps
vinnie
1960 chevy c10 frame with a 1966 cab
2002 dodge intrepid r/t
2004 chevy 2500 4 door short bed
mnky30 is offline   Reply With Quote
Old 08-28-2008, 03:24 PM   #3
Rooster's 67
We can use the original crossmember just need to know what 73+ trucks had the 8 on 6.5 bolt pattern in a 2wd. 3/4 or 1 ton trucks?
Old 08-28-2008, 10:02 PM   #4
Rooster's 67
T t t
Old 08-29-2008, 09:13 AM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
All 3/4 tons with 8 lug wheels used the 6.5" pattern. The newer trucks have 6 lug, but I don't know what year they changed.
One tons, for the most part had 8 lugs. If the truck had duals, the suspension was heavier. Due to the dual wheel offset, the front suspension was wider, so avoid the dually trucks.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
