Old 08-29-2008, 01:24 PM   #1
acl
acl's Avatar
gas tank gromet.
Removing gas tank for deadening mat install. Is there a secret to getting the filler neck thru the rubber gromet . is there a trick to reinstall? Thanks
It is fairly new so rot should not be an issue Don't want to have to replace if not needed. Gary
acl is offline   Reply With Quote
Old 08-29-2008, 01:51 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: gas tank gromet.
Lots of silicone lubricant...
I've done it both with the grommet installed and without. It was easier to do without the grommet installed first.
I lubed the grommet up good and pressed it into the hole with a plastic dowel so as not to damage the rubber.
When I installed it with the grommet in already, I had to force it throught the hole. That's where the lube comes in.
68gmsee is offline   Reply With Quote
Old 08-29-2008, 01:55 PM   #3
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Originally Posted by 68gmsee View Post
Lots of silicone lubricant....
Lube always makes it slip in and out more easily...."nudge nudge wink wink"
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 08-29-2008, 02:33 PM   #4
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Wink Re: gas tank gromet.
Don't laugh, but K-Y jelly works great, and no silicone mess on the paint either.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 08-29-2008, 02:50 PM   #5
acl
acl's Avatar
Are we still talking about my truck when saying gromet installed and not installed are we talking on tank neck or truck to slide neck thru?
Old 08-29-2008, 02:54 PM   #6
68gmsee
Active Member
68gmsee's Avatar
Yeah, it seems it slid a little... But, yes, the first time I did it, I lubed the grommet real good and slid the tank out. Then lubed it again and forced it in when installing it.
The next couple of times, I installed the tank and then lid the grommet in from the outside. Now, I will add, it was a brand new grommet and therefore real soft. I eased it around the opening with a plastic piece.
