09-01-2008, 01:59 AM | #1 |
3/4 ton frames
i there any difference in the frame 3/4 to 1/2 ton on these trucks
09-01-2008, 06:42 AM | #2 |
its all about the +6 inches
Re: 3/4 ton frames
welcome tothe board!
The short answer is yes. There's added braces in a cpouple spots, and the cab mounts are lower. Other than that, pretty much the same. |
09-01-2008, 08:22 AM | #3 |
Re: 3/4 ton frames
Welcome #2!!
I`m not sure what you may be pondering.But,if you are considering replacing your 1/2t`s frame with one from a 3/4t,you`ll never notice the difference.The only thing you`ll run into is the rear cab mounts are located lower on the frame.So,the 3/4t (and 4wd) cab mount bushings are different/taller.So,you`ll need those for a 3/4t.
09-01-2008, 09:00 AM | #4 |
Re: 3/4 ton frames
with the differant cab mounts would i run into difficulty following the standard directions on shortening a lwb 3/4 frame?
09-01-2008, 12:50 PM | #5 |
Re: 3/4 ton frames
No problem whatsoever. You will have to move the mounts regardless of 1/2T or 3/4T frame. You can even switch the 3/4T mounts to 1/2T if you want. Take a look at my 67 CrewCab build. I've got some pretty good picture of the frame mounts. There are also 2 links that show how to shortend the LWB frame using different methods (step and 45 degree cuts). Good luck.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-01-2008, 02:55 PM | #6 |
Re: 3/4 ton frames
any particular reasoning behind the two differant cab mounts? pro/con's of each? thanks!!!!
09-02-2008, 12:17 AM | #7 |
Re: 3/4 ton frames
the only model to get the oddball cab mounts is the 1/2 ton 2 wheel drive.
All 4X4 trucks, and all 3/4 ton trucks, got the lower mounting point, which takes a taller rubber mount. It has been speculated (and basicly agreed upon) that the taller mounts that go on trucks with stiffer springs, is purely for comfort. |
09-02-2008, 06:22 AM | #8 |
Re: 3/4 ton frames
I think the difference in cab mounts mattered more to the engineers than our real world experience.I`d just leave them be and save the labor.Besides,your truck will be more comfortable if you listen to the engineers.
