Brake Master Question
I have a question about my truck I just bought. Its a 67 gmc 2wd shortbed. It has disk brakes in the front and I was told that it did not come equipped with them from the factory. It does not have a booster and the brake master is leaking, can I just buy a brake master for a 67 with out a booster?
Thanks for your help |
Re: Brake Master Question
The master cylinders are the same if I remember correct , just go to parts house tell them its for a 67-72 . they will want to know if its got disk . hope this helps
My ZipCode = 29673 2008 Silverado Z71 LTZ Wrecked New Ride SOLD 71-72 Custom A/C Parts Truck < selling parts 67 Chevy ShortStep SOLD 67 GMC SWB Step <-- For Sell 67 Chevy SWB Step <-- working on 2000 Road King <-- SOLD 97 F150 my ride for now 2006 Escape wifes ride HELP SUPPORT THE BOARD http://67-72chevytrucks.com/vboard/payments.php Great How To Thread http://67-72chevytrucks.com/vboard/s...d.php?t=157669 Vendor Sites http://67-72chevytrucks.com/links/browselinks.php?c=2 |
#3 | |
Thanks again |
#4 | |
Sierra Grande Club
(here's an idea for your avatar ![]() s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
its all about the +6 inches
no you do not need a booster, millions of disk brake vehicles have been built without it.
You DO need to figure out what master cylinder you have, becouse a drum/drum master cylinder is NOT the same as a disk/drum master cylinder. |
#7 | |
Retired Air Force Veteran
![]() Join Date: Aug 2007
Do you have any pics of the setup currently in your truck now?
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
It's a catastrophic success.
![]() Join Date: Jan 2003
With discs up front I'd lean towards you needing a 71-72 but its possible that it may be newer than that. You should be able to take it to a parts store and match it.
high-Tech Red Neck
If I was in your shoes, I would get a BMC for a 72 with front discs, that way you know it is going to work, does your truck have 5 lugs or 6?
"He used to be a pretty nice feller, now he's a welder!" |
#10 | ||||
not sure Quote:
Thanks for all your help guys!!! ![]() ![]() |
high-Tech Red Neck
If it is a 5 lug it has been converted to a 70-72, so the mc will work well with them because it is all OE equipment, 67-69's were 6 lugs in a 2wd.
#12 | |
Sweet, just what I wanted to hear!!! I will pick one up asap! Next question, will i need to get a new proportioning valve? Thanks Here are the pics that were asked for ![]() ![]() |
I have another question
in the pic above there are studs going threw to the engine bay side on the 72 master/w booster it is opposite they go into the cab ![]() how do I go about mounting it? the studs would just hit each other. or do i have the wrong pic? Thanks Last edited by Wilson_; 09-03-2008 at 06:23 AM. |
ok I have been digging around looking at pics and it looks like I need a bracket or spacer of some sort
As seen in this pic ![]() Is this correct?? Thanks |
#15 |
![]() Join Date: Sep 2005
yes you will need that bracket, check out the parts board as that is where everyone sells there stuff. or pay for a 25 buxs membership here which is good for a year and go over to the parts board and post a wtb over there. just remenber guys any selling in this thread will get it locked
#16 | |
high-Tech Red Neck
#17 |
Wilson that will be the best 25$ you ever spent . I know I have learned alot on here and its worth that to keep this site up . O yea like truckdude239 you will need the brackets . here is a link to member selling what you need http://67-72chevytrucks.com/vboard/s...oster+brackets
#18 |
they sell those combo booster/mc at autozone. I think they require a core charge if you don't have a rusty one to turn in. The combo package was only like $10 more than the booster itself. You will need to find the booster bracket with push rod for the pedal too...
gn4u2c2 had some for sale on the parts board...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Tags |
1967, booster, brakes, gmc, master |
