Old 09-02-2008, 01:55 PM   #1
Eyegore
What Hump?
Eyegore's Avatar
Oil & Tempature sending unit locations
on a 454. Help I'm not sure which is which, can someone please help? This is for my 78 camper special w/ tthe 454, they were disconnected and I cannot make out where the sending unit is.
Tom
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 09-02-2008, 07:15 PM   #2
Albatrossian
Georgia Boy
Albatrossian's Avatar
Re: Oil & Tempature sending unit locations
Oil should be next to the dist, temp should be on the side of the block or the water neck.. I have a similar problem trying to find out where to relocate the temp sender since I have headers on my small block and they're in the way now..
Albatrossian is offline   Reply With Quote
Old 09-02-2008, 07:42 PM   #3
Eyegore
What Hump?
Eyegore's Avatar
Thank you. I found the temp and it's working, and now I'll go search under the air cleaner.
Lil red 86 c-10
99 Sub
Old 09-03-2008, 09:11 AM   #4
manimal
manimal's Avatar
oil pressure should be down by the oil filter on a big block.
-Lance
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 09-03-2008, 02:59 PM   #5
Eyegore
What Hump?
Eyegore's Avatar
-Lance
I found a plug just above the filter and nothing at by the distributor, so I guess I need to pull the plug and put the sending unit in. Can anyone tell me the color or wire that conects to the sending unit. Mine has gauge, not a warning light so I need to know the correct color. Better yet does anyone have the chassis electrical diagram for it? 1978 Chevy c-20, 3/4 ton camper special.
Lil red 86 c-10
99 Sub
Old 09-03-2008, 07:37 PM   #6
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
on my diagram it was brown... mine is an '87 though.
and manimal is correct... that's the only place to install a sending unit (that I've found) on the BBC.
www.alldatadiy.com has all the diagrams and their subscription is cheap.
Kenny
87Lowrider is offline   Reply With Quote
Old 09-03-2008, 08:04 PM   #7
Eyegore
What Hump?
Eyegore's Avatar
Kenny
That's what I figured out, the problem though is that there is now a plug in the case, so I'm looking for the electrical schematic to determine which color wire is correct. My Chiltons manual shows brown also but that is for a warning light according to the manual and i'm not sure if there the same color wire for gauges.
Lil red 86 c-10
99 Sub
Old 09-03-2008, 10:07 PM   #8
87Lowrider
87Lowrider's Avatar
What kind of gauge are you going to use? I used the existing TAN wire, snipped both ends, connected it to the sending unit and to the control box (dakota digital) and my oil gauge works great.
You may have to run a new wire up to the dash to hook up your gauge and use the tan wire for the ID-10-T light.
Ken
Old 09-04-2008, 10:16 AM   #9
Eyegore
What Hump?
Eyegore's Avatar
Finally, I found the sending unit, left side just behind the power steering box. I cannot tell the wire color though, some dark color with a grey stripe I believe, but i'm color blind, so it could be about anything.
So what would be the reasons the gauge would not be working? Is there a way to test the lead to make sure it is sending properly? Is there a way to test the sending unit?
Thanks ahead of time.
Tom
Lil red 86 c-10
99 Sub
Old 09-05-2008, 12:16 AM   #10
manimal
manimal's Avatar
try grounding the wire to see if the guage works.
-Lance
-Lance
Old 09-05-2008, 12:20 AM   #11
Eyegore
What Hump?
Eyegore's Avatar
-Lance
Thanks Lance.
Lil red 86 c-10
99 Sub
Old 06-25-2014, 06:24 PM   #12
davepl
davepl's Avatar
Old thread, but in case someone comes here looking for the info:
On my harness the wire is blue. On my '69 passenger cars its blue in both cases. Shop manual says "20DBL" which I'm going to assume is 20 gauge dark blue.
I can't get sensor I bought from LMC to screw into the block (BBC small port by filter). It LOOKS like it should. Maybe it's metric :-(
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
