Old 09-02-2008, 08:05 PM   #1
6t9ls1
lowering blocks for air ride
hey all new member here from va. im currently building a '69 gmc thats gonna have a pro touring, g machine kinda feel. my question is on the rear suspension. its got trailing arms and soon too have bags but can anybody point me in the direction of a set of 3'' lowering blocks, the biggest i have found for these trucks is a 2''. thanks for the help
6t9ls1 is offline   Reply With Quote
Old 09-02-2008, 08:47 PM   #2
SCOTI
SCOTI's Avatar
Re: lowering blocks for air ride
You'll have to make them yourself. 3" blocks for 6X-72 coil suspensions aren't marketed or manufactured that I've ever seen. Obviously you could stack a 2" & 1" block on top of each other & have u-bolts made the appropriate length.
That being said, a 3" block isn't going to really help w/the pro-touring 'feel'. It might give the 'look', but the axle that far above the leverage of the arms won't improve geometry or stability @ all which is the basis of a g-machine.
I would suggest 2" blocks max. Maybe we can help figure out a better way to meet your goal: How low are you trying to get your truck? What other parts do you plan to use?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 09-02-2008, 09:56 PM   #3
6t9ls1
basically i dont have a 100% plan on the rear suspension. i wanna be around 5'' at ride height. i have been thinking of useing ece trailing arms and crossmember with a watts link rather than a panhard bar. i am also open to any other ideas for a rear suspension. also, as i know its gonna make a differance, i plan on running 20x12'' rims in the back.
Old 09-03-2008, 09:21 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Don't you have to run a narrowed rear end to fit 20x12's?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-03-2008, 10:14 AM   #5
SCOTI
SCOTI's Avatar
Not on coil suspension trucks. You would use more back-spacing than a shorter housing would require which might make the difficulty level go up a notch when changing a tire.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-03-2008, 10:22 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Cool. I was just thinking if you needed to narrow the rear to run a 12" wheel, you could incorporate some of your drop in the mounting pad.
Articles-
"Refining Sierra"
Old 09-03-2008, 12:43 PM   #7
SCOTI
SCOTI's Avatar
Although it would look better IMO w/a narrower housing, you can get away w/a 14" wide wheel (15" lip to lip) w/9.75"bs & not hit the frame rail on the trailing arm suspension 6X-72's. Once you add blocks, it changes the relationship of dimensions & would require larger diameter wheels for sure.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-03-2008, 01:12 PM   #8
jkaylor68gmc
jkaylor68gmc's Avatar
I might be able to help you with that, let me make a call.
1947 International KB-1
1957 Chevy Bel-Air riding low
1962 swb fleetside
2002 Chevrolet Silverado 7-inch lift on 35 Daily driver
2016 Chevy Tahoe Better halves ride
jkaylor68gmc is offline   Reply With Quote
Old 09-03-2008, 06:42 PM   #9
jkade
jkade's Avatar
I have some homemade ones that are made from some 2x6" tubing and the long u bolts that are new to go with them for $40 bucks if you want to finish welding the insets in. I cut some dom to keep them from crushing when you tighten down the bolts but never welded them in. The bolts cost me $40 but that is the old bolts in the pics and the others a new.
jkade is offline   Reply With Quote
Old 09-03-2008, 09:51 PM   #10
6t9ls1
i appreciate the feedback, and Jkade ill keep you in mind if i decide to go the 3'' block rout. One other question though, is there anybody that has or is running a link style suspension with shockwaves. How would that work for what im after
1969 GMC Long bed 2wd-Work in Progress
1987 GMC Short bed 2wd- 283(lunati voodoo cam, aluminum intake, edelbrock 600 carb, headers, msd ignition), 700r4 w/2800 stall, 4.88 limited slip, more to come
Old 09-04-2008, 09:39 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
You could run Shockwaves on the rear, but you have to factor in the length of the unit. I think they need a mechanical advantage like a cantilever system offers to produce the amount of lift needed for the rear.
Articles-
"Refining Sierra"
