Jonny
83 Chevy diesel wiring HELP
I just bought a 83 chevy c-20 diesel, brought it home, and relized the wiring is fubar. I need some help with a wiring diagram and some advice on getting the dual tanks and "water in fuel" light working.
thanks in advance.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
Jonny
Re: 83 Chevy diesel wiring HELP
Well, after getting into the truck a a little, I have realized that I'm going to need to rewire about half of it. It is working for now, but I want to get it right.
Any help is highly appreciated.
BAD BOW-Silverado XST
Hey fellow Austinite!! Check with www.autozone.com for wiring diagrams. Pictures too.
I have a complete 83 factory service manual too. I just need a good copier. Parts are plentiful around Austin too. |
Jonny
Thanks for the autozone.com tip. Unfortunately there diagram is good for about half of what I need. It doesn't show anything for a diesel truck.
Professional Grade
What diesel specific systems need to be re-wired? Should only be the low coolant & water in fuel light circuits, high idle / timing advance circuit and the glow plug circuit. Everything else is fairly common to a gasoline engine.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Jonny
Yup, all that stuff you said, but I am also splicing it to a cummins motor. The dashlights are out and I have 8 or so loose ends under the dash, plus the dual tank wiring ends fust after the switch. This is gonna be one hell of a ride...
I'll scan some pages tonight. E-mail them in the morning. PM your address.
Wow a Cummings? 24 valve motor? Turbo?
HMMMMM, I think your better off borrowing my book. You can make copies of what ever you need. |
