Old 09-05-2008, 07:39 PM   #1
72gmcshorty
72gmcshorty's Avatar
Need frame help...
The PO tried to weld his own bumper brackets onto the front and rear of my 2wd 72 blazer. Unfortunately he managed to butcher and burn holes instead. I would like to know if the rear part of the frame (the part that angles down) is the same for a pick up and a blazer?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 09-05-2008, 07:42 PM   #2
72gmcshorty
Re: Need frame help...
I know truck frames do not bend like this but could i use a truck frame for a donor?
1992 Gmc 2wd
Old 09-05-2008, 07:50 PM   #3
72gmcshorty
just lovely, quality work
1992 Gmc 2wd
Old 09-05-2008, 07:54 PM   #4
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Looking at your siggy, why not lop them off and run a roll pan?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-05-2008, 07:59 PM   #5
uncle
You could use the truck ends and go with the truck bumper brackets.
uncle is offline   Reply With Quote
Old 09-05-2008, 10:22 PM   #6
jaros44sr
jaros44sr's Avatar
Frame horns are out there, I found a set for the front. Rears should be available as well...Check out the classified and run a WTB, guys on here part out all the time
Gotta love them PO's
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-05-2008, 11:38 PM   #7
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Why not just lob them off and run 71 rear brackets?
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 09-06-2008, 12:31 AM   #8
pumpkin
pumpkin's Avatar
I have some frame ends, and I'm close
pumpkin is offline   Reply With Quote
Old 09-06-2008, 02:09 PM   #9
72gmcshorty
I am undecided about a roll pan because I also like the sport bumper. Can someone explain the difference between the bumper brackets? Pumpkin, sending you a pm.
1992 Gmc 2wd
Old 09-09-2008, 05:41 PM   #10
DANTES JIMMY
DANTES JIMMY's Avatar
Wow that really is some top notch work there
lol
DANTES JIMMY is offline   Reply With Quote
Old 09-09-2008, 05:43 PM   #11
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Now that I look at it again, I think your rear horns are fine,
just grind of those welds, and adjust the end tabs, whalaa
Old 09-09-2008, 07:12 PM   #12
72gmcshorty
The fellow who did the "welding" ended up melting through the vertical sides of the horns. You can kind of see it next to that bolt on the left horn
1992 Gmc 2wd
Old 09-12-2008, 09:42 AM   #13
ilovetara
My truck is in pieces!
ilovetara's Avatar
i have a clean frame in my garage. I am in Abbotsford if interested.
69 Chevy C10 Long
Finally down to the frame!
My Build Progress Pics
ilovetara is offline   Reply With Quote
Old 10-06-2008, 07:17 PM   #14
72gmcshorty
Could someone post a picture of the 2wd 71 style frame ends? If I end up cutting off the end I need some kind of reference where to cut. Could a pair of front horns work in the back as well?
1992 Gmc 2wd
