F/S Blazer bucket seat tracks !!
i have a good pair seat tracks 75.00 shipped Complete! also a blazer fuel neck 43.00shipped
Re: F/S Blazer bucket seat tracks !!
Bryan, are the seat tracks off a 69-72 blazer seat and are they driver side if so I'll take them. thanks Mike
Mike,yes they are from a 72 ,and its for both sides pass/driver.
70 C/10-Work in progress
I'd be interested if down south passes.
In the garage 1999 Dodge Dakota Sport-Daily Driver 1972 Chevy K/5 CST AC/PS/PB/4x4/Tow Hooks/Tilt 1970 Chevy C/10-Current project |
sounds good if mike passes,your next .
Bryan send me your paypal address thanks Mike
Mike,Thank you for a smooth deal!!
K5drive
Can any one answer this question : Seats on my 71 blazer mount holes distance from front holes to rear holes doesnt match floor .The rear holes will end up where there is no "factory" spot welded backing plates:mm in the floor at the location of the rear mounts. Is this common to these trucks or did my truck come with bench seat ?
#9 | |
1971 Chevy Blazer CST 4X4 2012 Camaro 2SS/RS 2007 Avalanche 4X4 |
i am also pretty shure blazers did not come with a bench ,i do have a pair of seats i will sell CHEAP .If you need
![]() Join Date: Jun 2008
Bryan,
Do you have another bucket seat track? I need a driver's side real bad. thanks, 72junky |
i am sorry ,i only have bench tracks
#13 | |
Sounds like you either have utility buckets and your truck came with sport buckets or vice versa
Don`t all the K/5 seats bolt in the same?Aren`t the brackets the same on utilities as on sports?
72junky,I have the driver`s brackets.I just removed the seats and the driver`s seat is toast.So,I`d sell the bracket alone.
#15 |
Tim, I have a odd seat I would be interested in the pass seat if it's good and the driver side slide if junky passes. Thanks Mike
#16 |
Always on the hunt...
![]() Join Date: Sep 2006
The drivers side adj./slider tracks and pass. side pivoting mounting brackets are different between sport and utitlity buckets, the main difference is how they mount to the seat bottom.
#17 |
Active Member
![]() Join Date: Dec 2004
Ok, while we are on/or off the subject, are sport blazer driver seat brackets the same as truck driver bucket seat brackets?
#18 |
Resident Curmudgeon
![]() Join Date: Dec 1999
yes, and I need a set. Have 73-up truck bucket brackets to offer in trade
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#19 |
#20 |
SKINNY TIRES RULE!
I thought that the driver's tracks were the same as bench tracks. Can't you just take the far right bench track and move it to the right side of the driver's bucket? Never tried it, just assumed that was the case.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
#21 |
Resident Curmudgeon
Nope, not the same, they mount differently to the seat frame.
