09-08-2008, 03:14 PM | #1 |
You guys with a 4" Z??
What radiator is everyone using? My truck is a 65 witha small block and 4 inch Z. I didnt know if the majority of you are just getting a custom one made or if someone has found one at the junkyard that is the perfect size. Post some pics if you have them too. Thanks a lot.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=269019 Petitioning *No Regrets* MD/WV |
09-08-2008, 06:26 PM | #2 |
soon to be bagged64sub
Re: You guys with a 4" Z??
Good question. I will need to know the answer as well.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
09-08-2008, 08:56 PM | #3 |
One day...
Its nothing fancy but Mine is for a 74 chevy 1/2 ton big block (they say it has another row in it or something) im still working on fabbing the frame to it but it will fit below the hood. And the best part is $125 at local Oreillys
09-14-2008, 10:01 PM | #4 |
One day...
The radiator measures 181/2H X 34W
09-08-2008, 11:54 PM | #5 |
Would you happen to know the measurements on it? Thanks for the info thats a lot more than I had.
09-09-2008, 07:17 AM | #6 |
One day...
Ill get it measurments for you, its out at the shop it might be a day or so
09-09-2008, 07:12 AM | #7 |
How much height do you have to work with? Standard crossflow rad's are 19" tall then whatever width you can fit. I've been using Griffin aluminum rad's in most of my projects for years. New at Summit for around $180 typically. I was checking on www.speedwaymotors.com yesterday in their clearance stuff and noticed a nice aluminum rad 31x19 I think it was for $120. I'm assuming you will have a height issue with the frame so high so I can't help answer your question any closer than that, but the aluminum rad's have a much thicker tube so a 2 row with 1" tubes will cool better than the old 4 core rad's (with 1/2" tubes) the trucks may have come with from GM. My truck isn't Z'd so I have planty of room for any rad I want to run. I plan to use one of these crossflow units and fab the mounts for it.
66 Chevy Stepside tandem project My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902 Last edited by HotRodYJ; 09-09-2008 at 07:15 AM. |
09-14-2008, 10:49 PM | #8 |
Thanks a lot man. I am going out to measure right now. I really really appreciate it
09-15-2008, 07:10 AM | #9 |
One day...
No problem man
