09-12-2008, 01:00 PM | #1 |
Best transmission fluid for 3-speed?
Whats the best transmission fluid to use in a 3-speed colum shift? Its a 69 with the original transmission from when it had a I-6.
09-12-2008, 01:45 PM | #2 |
Re: Best transmission fluid for 3-speed?
usually 90weight gear oil for a 3speed manual tranny
09-12-2008, 02:22 PM | #3 |
got it
thanks |
09-12-2008, 04:06 PM | #4 |
its all about the +6 inches
I would say the synthetic gear oil personally... I think it's usually called 75/90... something like that anyways.
09-12-2008, 05:06 PM | #5 |
Stupid question, how do you drain the oil?
Not sure exactly what kind of tranny it is. the numbers are GM16 8(or 3)82547, it is a three speed column shift from an original I-6 and its a '69 |
09-12-2008, 05:10 PM | #6 |
Some of them have a drain plug that will"drain" out. I think there are some that you have to pump the oil/fluid out before you add the new stuff. I do not remember if our standard 3 on the tree tranny had a drain pulg or not.
09-12-2008, 05:10 PM | #7 |
I am a Referee of life.
Some have a drain in the bottom of the tranny,others don't.Usually a vacuum pump is used to remove the gear oil from them.I have pulled the side cover to get the last of it out(the truck was in a flood up to the bottom of the windows).If you pull the side cover be very careful since the shift forks may not line up if you aren't familiar with them.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
09-12-2008, 05:19 PM | #8 |
ok. i'll pump it.
i've been hearing a funny wine, tansmission rpm specific. almost like going fast in reverse just not as loud. the level was slightly under the one plug (on passengers side), 1/2" but it was dark brown like engine oil. ??? |
