Big Red & Mister Blue...
Steering coupler and gear problem
Hello
I have a leak on the input shaft of the steering box and the rag joint is broken, so i decided to change the steering gear and rag joint [a brand new rag joint and coupler] Well the rag joint i got from LMC doesnt fit the input shaft from autozone, it should because the difference in diameter is 0.002", i tried to tap it in with a mallet but the coupler started to scrape the splines on the steering gear and cant put the old rag joint because the old pump and the coupler are of a smaller diameter. Counted the splines on the rag joint and thats 23 and on the steering gear 30-31. Besides i tried calling LMC before i ordered the rag joint and for some reason they sell parts but dont have tech support ![]() Any sugestions, even if it implies rebuilding the old steering gear... ![]() PS any recomendations towards a steering shaft convertion [the one with u-joints] will be much appreciated.
K10 1967, SM420 & Rockwell T221 ![]() C1500 1991, 305 CID, Ext Cab, Full Size bed, everything original except air cleaner. |
#2 | |
Inline 69
Re: Steering coupler and gear problem
is it possible you have power steering? ...and ordered a Manual steering rag joint? or vice-versa?....the rag joints are different. jeff ![]() |
It cant be bud, LMC part# 34-0746 "F" states is a 68-72 and for integral p/s.
Actually the old rag joint is from manual p/s and it did fit the smaller OD p/s gear, but it was old and i lost the woodruff key so the splines are a little rounded off.
K10 1967, SM420 & Rockwell T221 ![]() C1500 1991, 305 CID, Ext Cab, Full Size bed, everything original except air cleaner. Last edited by killer_mike; 09-12-2008 at 10:34 PM. |
Any part numbers... or something, cause apparently theres a vast variety of rag joints and gear boxes...
My old steering box has the casting number: 7802644
that is the same number on my power steering box, I believe it is newer than 67-72 so maybe the year difference is you issue.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
What?
Ugh.. .This reminds me of one of my latest frustrations with the popular resto shops we all deal with! Well, my case sounded similar to yours.
In my case I have a 68 burb with manual steering, and I was dealing mostly with Orange County Car&Truck shop. Well, I ordered the rag joint for my rig. What did I get? a rag joint for another version of manual steering, being that the one I got had a section of no teeth where as mine required teeth all the way around. On the phone this shop sucked @$$, so I had to drive in and put my old one in their face. They ended up getting the right part from their car side of the house! The guy at the counter said he didn't understand why the truck counter didn't have this version in their shelves. I told them that there are basically two versions of manual steering boxes, both requiring two different rag joints do to the teeth design. Not sure I helped ya, but I just had to vent.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Oh man I just went thru this TODAY what a coincidence. Well I got my input shaft from Classic Performance and the rag joing from Advance Auto Parts.
I used part number 201 from a company called "Lares" it worked like a champ.... Manual rag joints are SMALLER than the power steering ones.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
![]() Join Date: Feb 2008
Al,
The rag joint you got from Advance, was the part no. 201 for power steering or manual. They list a part no. 200 as well but don't define which was is for manual and which one is for power. Thanks. |
#9 | |
Posted via Mobile Device |
If your old coupler fits ok, just get a rebuild kit for the rag joint and fix it. You just replace the rubber and it's good as a new one.
"Negative people always seem to have a problem for every solution" |
I had the same problem. I had a manual steering box rebuilt and thought it would be a direct replacement for the one I had on the truck. I was wrong, I ended up going to advance and ordering all the rag joints that were listed between 67 72, brought in the rebuilt box and found the one I needed. Only had to pay for the one I took out of the store. I still have the one from LMC that doesn't work.
Learning curve from a 40+ year old truck is always there.
1970 C10 LWB (Grandfather's Truck) 5.3 4L60E 2012 Victory Cross Country Touring I'm not wasting money on my truck/bike, I'm helping to rescue the economy one mod at a time. |
