wiring help on 6.2 diesel to 350 swap
hey guys, i need some help from you guys that know your wiring. I have an 87 chevy 1 ton rollback ive been working on. it was a 6.3 diesel truck. I swaped in a 350, w/ hei dist. Anyways, the truck is an absolute wiring mess. someone had cut wires, took off all the loom, its bad. I want to know the absolute minimun wires this thing needs to have lights, blinkers and run. so far i have the wire to the starter (purple i belive) and the main power to the starter, it has alt wiring, and dist wire. What wires do i need to power up the fuse box?
i know the power goes to the starter and the ground to the block. Does the wire off the alt power up the fuse box? it has that fuse block on the firewall but there are wires going everywhere. as far as gauges go all i need is the speedo and the rest i can put mechanical gauges in under the dash. so if anyone can help me get this thing running thatd be great thanks!! Matt
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
Re: wiring help on 6.2 diesel to 350 swap
The main battery cable attaches to the starter right ? From there a 10 gauge wire comes up from that same terminal and connects to the alternator, then to the block on the firewall. The fusebox then gets it's power from that block.
If it's just the engine side of the harness that's hacked, it will unplug from the fuse box and one in good shape from a donor truck will hook right in.
1977 GMC Sierra Grande |
would an engine harness from a gas motor truck work with the cab of a diesel powered truck? i already put the gas motor in the truck.
