New here and wanted to Say hi heres a 1969 4x4 C20 I think I stole yesterday. 307 V8, Muncie SM465 manual trans, Rockwell Timkin 221 transfer case, Dana 44 full float front axle with Spicer hubs, Runs good, needs a good tune up has been sitting for about a year.
![]() Join Date: Feb 2000
Re: Hi All
Definitely post some more pics when you can. That is interesting as my 69 K20 also had the mighty 307 but mine had a 3 speed manual until I converted it to 4 speed and bbc powered.
Am I correct in assuming you have the Eaton HO52 rear axle? How about a factory No-Spin (Detroit Locker). Power steering or power brakes? Can you post a pic of your SPID on the inside of your glove box? Just a heads up, for sale info needs to go into the classified section. You'll need to be a member to post in that section but you'll probably find the $25 membership fee is pretty reasonable for the great info throughout the board and exposure you get in the classified section.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Re: Hi All
Thanks again, I didn't know that about the classifieds, Here are a few more pics I will take more pictures and post this was the add when I bought it, I will investigate and let you all know whats really there, for $450 I really didn't care as it runs and drives and looks good. 1969 Chevy Pickup K20 (4x4 version of C20) 307 V8, Muncie SM465 manual trans, Rockwell Timkin 221 transfer case, Dana 44 full float front axle with Spicer hubs, corporate full float rear axle
#4 | |
I built it
Re: Hi All
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
Re: Hi All
What is meant by a corporate full rear axle?
Re: Hi All
You have got to be kidding me! You go that for $450??? Deal of the century right there IMO!
You are welcome for the info on the classified section. You can scroll up to your first post and hit the "Edit" button to change the info about selling the plow. The mods will appreciate that. Again, you got a killer deal on that truck!!!
Re: Hi All
Oh a little maintenance suggestion, make sure you keep your transfer case gear oil fluid full - I screwed up and let mine get low and ended up loosing one of the input bearings. The Rockwell T221 does not take kindly to low oil because when it gets low, the input shaft gets starved for oil.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 09-23-2008 at 12:18 PM. |
Re: Hi All
Thanks I flatbedded it home just for that reason, I want to change and check all fluides before driving it too far. I too couldn't believe the price. Thanks again for the info I found the edit button.
![]() Join Date: Aug 2007
Re: Hi All
Thats a clean looking truck, inside and out. Nice Score!
Re: Hi All
$450!!!!! What a score, thats a sweet looking truck!
![]() Join Date: Oct 2006
Re: Hi All
Wow, thats a smoken deal there. Did you knock the guy out and take the keys or what!
![]() Nice truck and welcome. |
Re: Hi All
Nice truck, How come things like that don't happen to me?
Ron
Member #111 68 C-10 ![]() 70 ![]() 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
![]() Join Date: Oct 2005
are people in your area generous? or did you steal it and leave a pitty $450 hahaha
WTB 1972 CHEVY 3/4 4X4 1971 chevy c30 4x4 NAPCO (project) 1972 chevy 3/4 4x4 350/350 4spd, tach, tow hooks,radio delete,heat delete,hubcaps,lockers 1972 chevy 3/4 4x4 383/350 dads original farm truck tilt,tach,tow hooks,hubcaps,radio delete,heat delete 2006 chevy LBZ crew cab duramax,4 inch,beadlocks 2015 chevy tahoe Z71 my fifth one,love em 2016 chevy 2500HD Z71 LTZ duramax midnite 2018 chevy suburban Z71 midnite |
Re: Hi All
Thanks for all your replys, I'm looking forward to going through it. I'm sure the questions will start flying soon.
#15 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Hi All
Very nice truck, and an incredible price!!
I like the color, too... ![]()
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#16 |
![]() Join Date: Nov 2006
Re: Hi All
Welcome, and WOW what a deal you got. Nice truck.
#17 |
Re: Hi All
Thanks for all your comments, I'm doing a complete tuneup and changing all the fluides this weekend. Any special oils I should use that are any better than any others?
#18 |
![]() Join Date: Feb 2001
Re: Hi All
Welcome to the site. Look around there is a lot to offer here. Great bunch of guys here in the 4x4 area.
#19 |
Re: Hi All
Your axles, manual tranny and transfer case all use the same 80w90 gear oil. I've often wondered if it would be helpful to use a synthetic gear oil to cut down on drag but haven't tried it. Rather than buy the small containers of gear oil, I pick up a 5 gallon container and a hand pump that goes in the container. You won't need that much of course but I find it is good to have on hand.
Anyone try synthetics in the axles, tranny and t/c that can comment on that? No real suggestions on the coolant or power steering fluid - I usually just by what is on sale at my local parts store. I like Valvoline 10w30 but use Rotella T these days in the same 10w30.
#20 |
Re: Hi All
Great, I have close to 3 gallons left after changing the fluids in my 1951 Farmall A tractor, that was last weekends project.
#21 |
Re: Hi All
That should mean it is a Eaton HO52 which is a full floating rear axle. If you break an axle shaft, you can still drive the vehicle. The Eaton axle has a drop-out thirdmember which means you could pull the thirdmember and swap in a different axle ratio relatively easily.
Here's a link that gives a good definition of each type of rear axle.
#22 |
Re: Hi All
Thanks Yukon....is there a certian stamped # to check to see if thats what I have?
#23 |
Re: Hi All
Does it look like this?
![]() This is an Eaton HO52.
#24 |
Tot Roddin'
Re: Hi All
Great looking truck, and
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#25 |
Re: Hi All
Thats a nice ride,congrats on scoring it! Did they throw in the plow as well?
