Old 09-24-2008, 02:40 PM   #1
big_al_71
big_al_71's Avatar
Power Steering Hose Dilenma!!!
Guys I have finally had it with this freaking power steering hose. I have ordered three different ones and none of them will fit properly.
I am using brand new parts based on a 71c10 2wd factory set up. The pump and the steering gear box are bolted and fit perfect so I know I have the right parts however the pressure hose is the one that I am having a problem finding the correct one.
Does any of you have the part number or a suggestion of what hose I should use?
In fact if you have a picture of the hose you used it will help me greatly. Downhere this trucks are NOT common at all like a camaro, corvette or a chevelle.
Albert
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-24-2008, 02:42 PM   #2
Luvlegs
Luvlegs's Avatar
Re: Power Steering Hose Dilenma!!!
The ones I'm familiar with come with a brass fitting that screwed into the back of the pump - then it all fit together. I'll see if I can find the part number... it came through Advance Auto.
Can't find it just yet - check in my gallery and you can see the pics of my pump and lines - it's a 6 cylinder though but I think the fitting should be the same..... if you can see it in the back of the pump.. best I can do at the moment, don't have my files with me.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 09-24-2008, 02:56 PM   #3
big_al_71
big_al_71's Avatar
thanks I will check your gallery.
The biggest problem is the 90 degree behind the pump..
Old 09-24-2008, 03:15 PM   #4
Yukon Jack
Yukon Jack's Avatar
I bought one for my 69 K20 and it fit perfectly but when I bought one for my 70 K5 it was way wrong. Ended up buying another one for a 69 K20. Course there is absolutely no difference in that area of a 69 K20 and a 70 K5 so I can't imagine why they were different.
Unfortunately it sounds like your just gonna have to keep trying different ones.
Maybe give one for a 69 K20 a try - the 4wd's engine is set back a bit more but it still might work for you.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-24-2008, 03:41 PM   #5
Classic Bowties
Always on the hunt...
Albert
Hey Albert, after trying several different pressure hoses for fit & finished look, the one that I liked and have been using on small blocks both C & K series is a Parts Master p/n 71065, I added a couple of extra pics of this pressure hose installed on 68 C/10. Good luck on your hunt!
Classic Bowties is offline   Reply With Quote
Old 09-24-2008, 04:01 PM   #6
68caliRat
Need a bigger hammer..
For my BBC I brought my entire old hose to a hydraulics shop and they brazed on some fittings and made an entire new hose out of regular stock. so now when my hose get old and brittle I can just have a short length made up and bolt it to the fittings..
1968 GMC 3/4 LWB fleetside Custom Camper
2018 Silverado High Country 2500HD Duramax 4X4
68caliRat is offline   Reply With Quote
Old 09-24-2008, 05:47 PM   #7
big_al_71
big_al_71's Avatar
Guys Thank you!!!!!!!!!
Classic Bowties big Thanks for posting picts!!! It helps me alot, I am going to try to find it tomorrow morning.....
Old 09-24-2008, 05:58 PM   #8
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
For future reference I have found that http://www.rockauto.com/ is a great source for looking up not only part numbers, but many a picture of the actual parts are often there as well. Then I call the local shop with the number which makes the trip a one time deal instead of trial and error.. Hope it helps,
Drew
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 09-24-2008, 06:09 PM   #9
big_al_71
big_al_71's Avatar
thanks Drew!!!!
Old 09-24-2008, 06:20 PM   #10
Sammy
I had a similar problem finding one that wasn't..sorta bound up & twisted badly. I ordered another new one from GMC Pauls, it fit like a glove no binding, easy no leak install. I think mine was the angle and incorrect position of where the 90 was swedged.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 09-24-2008, 10:08 PM   #11
big_al_71
big_al_71's Avatar
Sammy do you have the part number and picts?
Old 09-25-2008, 06:25 AM   #12
Sammy
No but was easy to obtain. I just went to GMC Pauls site. it was more expensive probally but figured I would use a known stand by your part board vendor. And it worked great for me after spending 3X's for others. Having ordered from him before if it didn't work I was going to return it.
