09-25-2008, 10:31 AM | #1 |
1983 Tilt Steering Column to 1978 Big 10?
I've found a tilt-steering column for my 1978 Big 10. It came out of a 1982 C-10. Does anyone know if that's a straight drop-in type of deal?
I've never done a steering column before, so I'm kind of nervous about messing with something that seems important like steering. Am I biting off more than I should? Yes, I'm a big old wuss.
1978 Silverado Big 10 - "The River Runner" 1969 GMC C/10 - "The 2008-09 Winter Project" |
09-25-2008, 05:18 PM | #2 |
Robert Olson Transport
Re: 1983 Tilt Steering Column to 1978 Big 10?
i dont think it will work.. the 83 has wipers in the turn signal and the hole is different.. if its an 82 ( it says 83 in title 82 in thread) it should work... you may need the lower shaft tho to make it work,,, hope that helps
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
09-25-2008, 05:22 PM | #3 |
I think wipers were in the dash until 1985.
1986 Chevy 3/4 Ton 4X4 |
09-25-2008, 05:23 PM | #4 |
Yeah, I screwed up my post -- the guy says it's an 82. I'm checking with him about the wiper controls.
09-25-2008, 07:16 PM | #5 |
It will interchange as long as it's an '83 on back. 1984 was the year that the wiper switch was moved to the turn signal stalk. ...Joe
I'm not speedin'! I'm qualifyin'! |
09-25-2008, 09:17 PM | #6 |
Happy to be here
Not exactly. There were some changes in connector plugs and shaft shape along the way. It can be made to work, but it might not be a straight across swap.
09-26-2008, 12:55 AM | #7 |
6.0 powered square
my buddy has a 78 big 10 and he did the swap with a 84colum bolted up just fine, just keep using the dash mounted wiper switch.
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
09-26-2008, 05:18 AM | #8 |
Old Heap Driver
I used an 85 Blazer column in my 80. I wired up the column wiper switch (and a delay module) to my existing wiring. The dash switch is still there and I'll use that spot for something later on. I also had to mess with the ignition switch, I just can't remember what the issue was.
My truck is a manual tranny, so I still need to eliminate the remains of the column (automatic) shifter.
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
09-26-2008, 09:32 AM | #9 |
Well, the guy says no wiper controls on this column, but I'm gonna take a pass, as I really have more important mods to do.
Thanks for all the help, folks...much appreciated.
