09-29-2008, 12:28 PM | #1 |
Steering wheel removal?
I'm a bit of noob to my truck 88 s-15,my question is.How do I remove the steering wheel from the column,I have to fix my indicator switch?Also will the plastic sleeve slide off that surrounds the column at the base of the steering wheel.Any help would be great.
09-29-2008, 09:40 PM | #2 |
Re: Steering wheel removal?
You will have to get a puller. What do you mean by indicator switch? Also is it a tilt column?
10-07-2009, 12:35 AM | #3 |
You probably have it off by now. But just in case, you just gently pull the horn button off. That exposes the nut. Then, there are 6 star nuts to remove as well. Later
