dave's 64 project.
here are my 2 64's that i'm gonna combine hopefully into 1. (with all of ya'lls help).the blue one is a 3/4 ton frame that's been shortened. i'm not real fine of the frame job so thats why I wanted the grey one. i have a 283 i think in the blue truck and a 700r4 in my laundry room. the grey frame is great and the cab appears better. i hope to use some pieces of both, and alot of aftermarket parts. ya'll let me know what you think. i got the grey one for $400 and lost my butt on a trade for the blue one. (hopefully i won't be so stupid next time) i wanna swap in the engine and tranny as soon as possible so i can enjoy driving it some. it ain't no fun just sitting there. i wood like to redo a wood bed cheaply until i can get a swb fleetside bed.
Re: dave's 64 project.
planning on taking off the wood bed and using rust bullet all over the frame. start at the back and work my way up front before i install the engine. ya'll have any better ideas?
sweet there are some smart guys in here to help, i agree that blue one has some nasty frame issues!
1961 crewcab
I didn't notice before, but you scored with that factory fleet rear bumper on the $400 truck!
with the 2 you definatly have enough to build a good truck now , all you need is a box. |
UCA63
I see you also scored a pair of helper springs (don't see many of those).
looks like a much better start than the blue one. T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
looks like you definitely have plenty of good parts between the pair
I don't think that is a 283 though. wrong heads, wrong alternator bracket, looks like a newer swap. there should be a number behind the drivers side head that you can run and see what it is
![]() ![]() Last edited by joe231; 10-04-2008 at 02:30 PM. |
Step Brother
Looks like you will be able to build a nice truck out of the two.....
#8 | |
60-66 Nut
Hollister, CA.
![]() Join Date: Sep 2006
see the ?able body mounts
Definately was a 3/4 ton frame.... Looks like you will be able to build a sweet truck out of the two.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 10-04-2008 at 11:49 AM. |
New Member
Good luck on your project
Anthony 63 chevy stepside SWB 57 chevy 2dr hrdtop belair |
what do you think the engine is then? i cant get to the back of the block to find the numbers. nothing else the guy told me about the truck is correct so i won't be surprised if i find out it's something else. as long as it turns out to be a chevy v8 i should be o.k. with it. i dont know if ya'll read my other post but, how do i know where to cut the hole for a floor shifter in the grey truck. i have a 700r4 in my laundry room that i wanna put in. i also wanna use one of them tall shifters (gennie or lokar)how tall is enough? i see them in all different lengths.
just ordered a quart of rust bullet from summit. i gonna start with the rear frame and work my way forward. any pointers?
60-66 Nut
You'll want to get as much of the loose rust, dirt and grease off as possible. One way to do that is with a cup style knotted wire brush on a 4 1/2" grinder. After it is as clean as you can get it, wipe it all down with something like lacquer thinner or a specific wax and grease remover. Then apply the Rust Bullet. You'll want to be sure that the temperature is warm enough and long enough for the Rust Bullet to cure thouroughly.
#14 | |
Its Deja Vu time again
http://www.67-72chevytrucks.com/vboa...06#post2918506 To remove the stuff I hit the truck frame with a power washer to get rid of all the really loose chunky stuff then I hit it with one of these wheels. Just screwed right on to my 4-inch grinder. ![]() After that I hit everywhere I couldn't hit with that with wire brush followed by a foam block that was covered with sand paper. ![]() I blew the entire surface with air to remove the film then hand washed with a damn towl. Well I should say many damp towls. ![]() I'd guess the most important part like mentioned is having a clean as possible surface and most importantly no oil or grease. Last edited by kizer; 10-06-2008 at 12:00 PM. |
#15 |
1961 crewcab
I think those shifters have options for where you want to place them on the tranny, I would get the tranny in first , and then see where the shifter could be located, and then cut he hole.
with an automatic you can use a shift cable as well, maybe they have a floor mount shifter, then all you need to do is drill a hole for the cable. |
