Old 10-02-2008, 10:44 AM   #1
ap2002
cheapest fix for bed floor?
what will be the cheapest fix in replacing a rusted bed floor? what kind of metal can be used? i dont care for the humps on the bed floor, it can all be plain/flat for what i want.... i do not want to go with the wooden floor cause im not real easy when it comes throwing stuff in back of the bed.
thanks!
1971 C-10 SWB - LS swap w/4L60e, 20x8.5front 20x12rear,
1968 C-10 SWB - 454 BB TH350 -Gone!
ap2002 is offline   Reply With Quote
Old 10-02-2008, 11:10 AM   #2
Rack Man
Re: cheapest fix for bed floor?
Hit Craigslist & Find a Donor!
Rack Man is offline   Reply With Quote
Old 10-02-2008, 03:00 PM   #3
haysonj
haysonj's Avatar
thanks!
3/16 diamond plate the extra weight helps with traction
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 10-02-2008, 03:18 PM   #4
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
you might try finding a salvage yard that has several old big road signs. They are aluminum so they won't rust, but it would be fairly cheap and effective.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 10-03-2008, 11:09 AM   #5
crites_72
crites_72's Avatar
Thats alot of diamond plate wasn't the cost high? I thought about doing the same thing on my 68. I've got about 3 50cent piece size holes by the cab.
DJ
crites_72 is offline   Reply With Quote
Old 10-03-2008, 11:13 AM   #6
lowriden58
lowriden58's Avatar
the problem with placing diamond plate or other metal over the existing floor is moisture gets trapped between the two and causes it to rust even further. the PO did that to my 71 and boy what a mess that was i just cut it all out including the stock floor
*edit* what i did for bed sills is cut 6' sections of 2x3 steel tubing. and my plans are to completely sheet metal the floor/sides. (eventually)
71 cheyenne lwb 300rwhp
best 1/4 time so far 12.8 @103
http://i195.photobucket.com/albums/z...en58/001-2.jpg
lowriden58 is offline   Reply With Quote
Old 10-03-2008, 11:44 AM   #7
haysonj
haysonj's Avatar
It is almost impossible to stop rust but what I did was spray the bed floor & underside of diamond plate with primer and under coater. the diamond plate was attached with stainless rivets on one foot centers an the entire bed was sprayed with the Linex bedliner. drain holes were drilled in the front to allow trapped moisture to get out. I also undercoated the entire under side of the truck. diamond plate cost $140 for a full sheet.
Old 10-03-2008, 05:03 PM   #8
novapower
we replaced ours with 3/16 diamond plate.we took all the bolts out and had just anouf of it left to lay on top and cut out a new floor.we used 2x3 tubing and some angle iron to make all new floor supports.then we primed it with expoy primer and then painted it.i think we have $ 150 in it.
novapower is offline   Reply With Quote
Old 10-02-2008, 11:14 PM   #9
ap2002
thanks for all the suggestions, im gonna go price some stuff...
Old 10-03-2008, 08:36 AM   #10
67mater
67mater's Avatar
let me know if you get any sizable scrap when you cut yours up!!
time is inversely proportional to money; that's why it takes me so long
1967 K10
1967 Camaro
67mater is offline   Reply With Quote
