10-02-2008, 10:52 PM | #1 |
I like turtles...
crew cab questions
hey guys, ive been lookin for a new project, and have been lookin for a crew cab. but for the 73-87 did they come with a v8 or a diesel? did they come stock with long beds? if they do, how hard is it to make it a short bed? and the most general questions will help me out. its gettin colder here in KS and im wantin me a winter project and i like the way mike nutts crew cab shorty looks, so any help will point me in the right dirrection, thanks
jrsmith
1979 Silverado- lowered 5/7, 20 inch Boss rims, everything shaved, caddy lights, billet interior, UP FOR SALE! 1983 Scottsdale-on the back burner...SOLD!!! 1992 Silverado- extended cab, stock for now, but no promises SOLD!!! 2006 Chevy Cobalt-college car, staying stock Whatever can't get fixed with a hammer, a roll of duct tape, a clothes hanger, a tube of glue, and a case of beer, can wait until tomorrow. |
10-02-2008, 10:55 PM | #2 |
Robert Olson Transport
Re: crew cab questions
they came longbed there are many threads here about people converting to shortbeds please use the search ... i believe most were gas if not all the diesel was later .. after 87... bigblock73 or captkaos would be able to better answer that part.. im not a diesel guy
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! Last edited by old Rusty C10; 10-02-2008 at 10:55 PM. |
10-03-2008, 08:06 AM | #3 |
I like turtles...
how hard is it to make a long bed into a short bed?
10-03-2008, 08:12 AM | #4 |
Happy to be here
Check the FAQ forum, there is a great write up there.
10-03-2008, 11:31 AM | #5 |
www.73-87chevytrucks.com
82-91 Crew cabs came with 6.2L diesels. All 73-87 trucks over 1/2T only came with Long beds.
If you follow OJOE's thread there is info on how he shorted his. You can also aquire a short bed and put it in place to see where the frame should be sectioned...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
10-03-2008, 01:04 PM | #6 |
I've seen crewcabs with big blocks, small blocks and diesels.
Has anyone done a crew cab short box step side?
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208. |
10-03-2008, 01:34 PM | #7 |
Junior Member
All of the factory units I have see were all long boxes. Motor wise you could get the diesel 6.2L.... small block 5.7L.... and big blocks 7.4L. My Crew is an 86 long box with a 7.4L
10-03-2008, 04:29 PM | #8 |
I like turtles...
ok ive been doin some research, and got some new questions. 1st, will a longbed frame work for a crew cab shortbed? 2nd, after cuttin the frame to make it a shortbed, do i have to get a different driveshaft? 3rd, how will all the shock, hanger, and shackles be moved if any, and where? if i find one i plan on baggin it, and body drop, so can anyone answer me these questions?
thanks jrsmith
10-03-2008, 04:30 PM | #9 |
I like turtles...
and can someone with a crew cab shortbed, measure how long it is from the front to the back? over all length, thanks
10-03-2008, 04:40 PM | #10 |
Junior Member
yes it can be done, You are going to shorten frame in front of the kick up and the frame hanger....
10-03-2008, 04:51 PM | #11 |
I like turtles...
so a lwb frame will work?
10-03-2008, 04:58 PM | #12 |
Im sure it will but finding a swb donor frame will make it easier to do.As said before check out ojoes build thread that is what i used as a guide to build mine.The driveshaft will have to be shortened, brake line will also.Check out my thread to.I am a hour or so away from mclouth and have family there so when your ready to dive i will be glad to come help.
http://67-72chevytrucks.com/vboard/s...d.php?t=304940 |
10-03-2008, 05:24 PM | #13 |
Dang! Wish you were closer to me!
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
10-03-2008, 04:59 PM | #14 |
Yes you use the lwb frame.. a short wheel base/ or short wide bed (which ever swb means to you) isnt long enough, you would have to lengthen it.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
10-03-2008, 05:04 PM | #15 |
I like turtles...
so i need a lwb donor truck then take the crew cab off, then do the modifying to the lwb frame to fit a shortbed?
10-03-2008, 05:33 PM | #16 |
I like turtles...
im lookin to do a 81-87 crew cab, but what year did they start adding computers in them? cause i plan on putting a 350 in it, but dont want to mess with the reprogramming of the computer
10-03-2008, 06:33 PM | #17 |
67-72 parts collector,…
jrsmith,... You will be cutting your original crew cab frame directly behind the cab and shortening that frame. OR,... you will get a 1/2 ton short wheel base frame and grafting it on to the rear of your crew cab frame. Do you want to keep the 3/4 (OR 1-ton) suspension or do you want to convert to 1/2 ton suspension? Look at member OJOE's thread on this subject. That will help alot. Shortening the frame is just the beginning. Bagging and body dropping will require some professional know how. Good luck!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-03-2008 at 06:33 PM. |
10-03-2008, 06:40 PM | #18 |
I like turtles...
well idk what would be better or easier to do, 1/2 ton or 3/4 ton frame. does this really matter that much?
10-03-2008, 06:50 PM | #19 |
OJOE's way,... in my opinion,... is the easiest, if converting to 1/2 ton. How much suspension or welding have you done? Read as much as possible. The "Search feature" is your friend,...
10-03-2008, 07:19 PM | #20 |
I like turtles...
well im just doin some research, i havnt found a truck yet, im seein if this is the way i want to go and how hard it will be to do. and i just read all of OJOE's thread, and this is the way i wanna go! im gonna go huntin for one tomorrow
10-03-2008, 07:49 PM | #21 | |
It followed me home?
http://denver.craigslist.org/cto/860444994.html
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
10-03-2008, 11:05 PM | #22 |
hey there jrsmith when you go looking for your crew cab dont rule out the duallys cause if your gonna cut it any way it dosent matter. http://67-72chevytrucks.com/vboard/s...d.php?t=303335
im going 1/2 ton from a donor burban g/l on the truck hunt |
10-04-2008, 02:16 PM | #23 | |
Wish that one was closer.
10-05-2008, 09:30 AM | #24 |
I might go and take a look at it next week if I finally get paid on a few jobs, hopefully its still around.
10-03-2008, 11:28 PM | #25 |
I like turtles...
ive noticed that they made crew cabs in 3/4 and 1 tons, but is there a way to covert all 4 corners to 1/2 ton with 5x5 bolt pattern?
