putting in 700r4
how do you find out where to cut hole for floor shifter for a 700r4? the truck currently has no hole in the floor? do i have to do a mock up first then mark where i need the hole?
Re: putting in 700r4
Run a cable type shifter for the 700 and all you need to do is make sure you have a straight shot to the linkage on the trans
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 Last edited by shortbed70; 10-05-2008 at 06:24 PM. |
i don't understand. where can i find more info on shifters. cable type vs what? so you bolt it to where if it shifts by cable, the floor? i'm currently searching for info online also.
i found this lokar http://www.lokar.com/product-descrip...op-shifter.htm why is it mounted to tranny just for looks? does gennie let you do cable mounts haven't found that yet Last edited by dhughins; 10-05-2008 at 07:05 PM. |
i see all these ads for rear mount shifters how do i know which i'll need?
pic of the tranny if it helps |
The Lokar type mounts to the trans housing itself - you can find illustrations at any Lokar dealer's site.
I went with the B&M cable-type - you mount the shifter wherever you have room to clear the seats; only the cable itself goes through the floor and wraps around to the driver side of the trans where its bracket mounts for the shift lever - pretty simple. |
My 700r4 is hooked to the original column shift.. that way i can roll 3 wide with no issues!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
Keepin it old school
The lokar mnt is for the manuel trans looking shifter now if your limited on space then run a b&m or hurst shifter and the cable is like a bike's brake cables only heavier and all you have to do is drill a smallhole for the cable. To anwser your original question if you want to go with the lokar piece then you will have to install the trans with the bracket and set it in place to get an accurate spot to cut.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
1962 C-10
Use a B&M Shifter. They are the cable type. You just need to drill a few holes and run the cable through. Work great!
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
KOFFIN DRAGGER
good advice,listen to the captain
If the life I live dont kill me, then I guess I'll never die! New updated stuff at www.kdrodworks.com My site still needs help, web guys and gals pm me. the best guys in the whole world: sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231 |
I bought the tv right deal from tci and it will not work on a demon but will work on a holly so...I still have and want to get rid of...pm also since I didn't do the tv I set it by pressure through the pressure port of the vb and got it a touch higher than stock. I will be going with a bowler tvright kit when the truck is done.
If you are gonna hook it up to the normal colum shifter ow would you go about that. Also when going from a th400 what else would need to be done. Sorry for stealing the thread.
Josh
- Josh Im not white trash, I'm one step above that..... more like white clutter |
http://www.tvmadeez.com/article/index.html
Throttle Valve Cable system 101 how the TV control system communicates to the Th-700R4 and Th-2004R transmissions. ---- http://purplesagetradingpost.com/sum...o/700R4p1.html 700R4 Information adjusting Th-700R4 transmissions. ---- http://www.bowtieoverdrives.com Bowtie Overdrives whole trans., parts and tech articles for 700R4 and 2004R automatic overdrive transmissions ---- http://www.tciauto.com TCI Automotive transmissions and assorted doodads ---- |
