Heater box question
I found a heater box at the junkyard, and the guy that pullled the the part (a non-A/C box) busted off the flange where there should be a bolt holding it to the firewall, but it's the one that people leave out anyways, so they don't have to drop the inner wheel well. Doeas anyone know if this will work O.K. or should I find another one? I'm wondering about the seal. The seal area is actually O.K.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Re: Heater box question
I have one in great shape you can have for 10 bucks and the shipping if you want.
Not to try and sell you, but there may not be enough pressure there and tightening the other bolts may cause that side of the lip to raise.
1947 International KB-1 1957 Chevy Bel-Air riding low 1962 swb fleetside 2002 Chevrolet Silverado 7-inch lift on 35 Daily driver 2016 Chevy Tahoe Better halves ride |
its all about the +6 inches
I'd roll with it. You probably only use your heater for a month out of the year anyways.
That's true, but I'm getting tired of using a towel as my defroster. Almost every moring it's dewey here.
Changed mine last winter, broke off the same by accident, I used the Black permatex RTV all the way around and have had no problems. Good luck, Mike...
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
Firefighter
I'd use it, mine has been like that for years and I have never had a problem with it!! P.S. Don't use Latex caulking or silicone to seal it, it causes rust I learned it the hard way!!!! 3M makes a black strip caulking that is the way to go!!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
curious....how does latex or silicone cause rust, when the heater case is plastic??
1997 GMC Sierra Ext 1965 Mustang |
