10-07-2008, 06:28 AM | #1 |
brake booster question?
I am replacing my master cylinder cause leakin from rear and where it bolts up to booster i noticed the pushrod coming out of booster was all wet and rubber gasket cracked! Is there a oring set for this or do i need a new one cause LMC does not show oring for booster! thanks would appericate the help and new to site and look fwd to visiting more!
10-07-2008, 11:09 PM | #2 |
Re: brake booster question?
Wish I could help but I'm not sure on this one. Only thing I can suggest is hitting your local parts house & look @ a rebuilt booster & see if there's a seal on them that you might be able to pick-up separately.
At least this will get moved back up to the top for ya if nothing else. Welcome to the site BTW!
10-09-2008, 04:57 PM | #3 |
no fluid in booster. the fluid is coming from the rear seal on master cylinder.
