10-08-2008, 05:38 PM | #1 |
Cleaning out my stash - a LOT for sale (Vintage Air, 700r4, etc) - Toledo, Ohio
I have a bunch of stuff that I would like to sell - all items are located in Toledo, Ohio.
Vintage Air (Sure Fit) Evaporator Kit - just bought this from a board member about a month ago - #75067-LCZ-A - in the same box I got it in - http://www.vintageair.com/cat2007/51.pdf - $475+shipping (SOLD) 700r4 from a 87 Camaro - was told it was ready to go - have not tested it since I bought it (6 mos ago) - no way to know for sure - figure it for a core - $120 - picked up in Toledo A/C parts for the firewall, and interior plastic components - no duct work - $150 obo 72 Front suspension and disk components - UCA, LCA, spindles, rotors, etc. $100 obo 72 Rear Axle - with roller tires on it - 3.08 gears (non posi) $100 obo (Pending) Buy the two above for $160 Blazer Utility Buckets - $175 obo - will need recovered 71-72 OE (non SS) Fine Lines set of SBC, 2WD TH400/TH350 Trans Cooling Lines - NIB - $30 + shipping Blazer Swing Away Tire Carrier (with hardware) - $200 obo 67 Front Quarter Panels - from TX - in epoxy primer - small bit of fiberglass in the bottom of one of them - cannot tell on outside - $200 for both obo 68 Rear LWB Bedside - will have to check on which side it is) - good condition - $60 obo sold 68 Bed Wheel Tub - decent condition - $50 obo LWB Bed - solid bedsides - but floor has holes in it - could be great for hauling wood or scrap - no tailgate - $70 obo 1967 LWB Truck - no motor/trans - basically a cab (rusty on the bottom), frame (straight and solid), bed (wood floor) and a tailgate (not great condition - but it works) - interior has been stripped - but it can go with for some extra $ - I do have a clear MI title for this one. Newer tires and rims. $500 obo - you can sell parts (core support/grill/tires/tims/etc.) off this and recoup your costs. 1972 Rolling Chassis - from TX - surface rust only - straight. Trailing Arm frame with 5 lug rollers on it. If you buy this I will throw the LWB (bed) mentioned above on this for you for free and include it in the price - $150 obo (Pending) Larger stuff will need to be picked up in Toledo, Ohio. Pix will be coming soon. PM me with your questions/concerns (or if my prices are way off). Thanks for your time. Edited for clarification of the bed being what I would throw in for free - not the LWB truck - Last edited by lks dcvn; 10-18-2008 at 03:24 PM. |
10-08-2008, 06:09 PM | #2 |
Re: Cleaning out my stash - a LOT for sale (Vintage Air, 700r4, etc) - Toledo, Ohio
pix 1
10-08-2008, 06:10 PM | #3 |
pix 2
10-08-2008, 06:11 PM | #4 |
pix 3
10-08-2008, 06:12 PM | #5 |
pix 4
10-08-2008, 06:13 PM | #6 |
pix 5
10-08-2008, 07:36 PM | #7 |
"GO DAWGS"
Is the Vintage air a complete kit ready to install. If not what is it missing. I know a guy here in town that is looking for one.
Thanks PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops Last edited by PT'S 70 CST; 10-08-2008 at 07:37 PM. |
10-08-2008, 07:48 PM | #8 |
Complete Evaporator Kit - no parts missing - I checked the inventory list when I got it from another member...
The part number is 75067-LCZ-A and it is described as: EVAPORATOR KIT: Air conditioning, heating and defrost combination designed specifically for your vehicle. Original deluxe control assembly in your dash connects to and controls this unit. Designed to mount to existing holes in your dash and firewall without drilling* or fabrication. Evaporator kit comes complete with all mounting brackets, hardware, louvers, duct hose, wiring harness and installation instructions. This is not the complete kit - but if you have the under hood stuff (condenser and drier) - you should be ready to go... |
10-08-2008, 07:39 PM | #9 |
Is this the same vintage air kit that I was in line for last month? If so I will take it!! I need it for the wifes burb. Let me know. I can paypal the money. PT, I'm not trying to jump in front of you. I was trying to get it last time. I will of course be after you.
SHawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE Last edited by jorgensensc; 10-08-2008 at 07:40 PM. |
10-08-2008, 07:55 PM | #10 |
call me i ll take the cab if is good 1-517-543-8691
10-08-2008, 08:12 PM | #11 |
"GO DAWGS"
So if your truck is a non factory air truck you will still need some stuff to insatll it. Also do you know if it will fit on a factory big block or is there anything different that you would need other than the pulleys and brackets.
PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
10-08-2008, 08:28 PM | #12 |
PT,
I know I'm shooting myself in the foot, but yes you would still need a compressor, condensor, and dryer. It will work for a big block also, you will need the pulleys and brackets also. you will need to buy the A.C. controls also if your truck didn't come with A.C. Hope that helps a little. (Although secretly I hope your freind doesn't want it ) Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
10-08-2008, 11:31 PM | #13 |
"GO DAWGS"
Thanks Shawn, its your lucky day. I called my friend and he has a 68 and does not have any A/C stuff and is going to try and buy a complete system. So I am going to pass it on to you.
PT
10-08-2008, 11:53 PM | #14 |
oh man, any idea on how you could ship the rearend?
Andy... '70 C/10 Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=298553 '71 K/20 Frame-off resto, SOLD!!! http://67-72chevytrucks.com/vboard/c...ct=2399&cat=12 '05 Silverado Z-71, CC SB, Daily Driver |
10-09-2008, 10:45 AM | #15 |
10-09-2008, 12:09 PM | #16 |
1972 K20
Hi,
Please put me next in line if the Vintage air stuff does not sell. Thanks |
10-09-2008, 01:44 PM | #17 |
jorgensensc - I will take it tomorrow to check pricing - USPS online says $35 (using my guesstimate numbers) - but want to give you an exact price.
No idea on how to ship the rear - if you know anybody coming through - you are welcome to have them pick it up and bring it your way... |
10-09-2008, 02:20 AM | #18 |
wish you were closer. I need that tranny and disc brake stuff
67 C10 Shortbed 327 05 F150 4x4 NO APPOLOGIES 's 02 Xpress X19 02 Yamaha VMax 150 www.xpressboats.com Nothing says 'poor craftmanship' like wrinkles in your duct tape |
10-09-2008, 04:44 AM | #19 |
me hopes jorgensensc dont take either . I will take The Vintage air per post 10
My ZipCode = 29673 2008 Silverado Z71 LTZ Wrecked New Ride SOLD 71-72 Custom A/C Parts Truck < selling parts 67 Chevy ShortStep SOLD 67 GMC SWB Step <-- For Sell 67 Chevy SWB Step <-- working on 2000 Road King <-- SOLD 97 F150 my ride for now 2006 Escape wifes ride HELP SUPPORT THE BOARD http://67-72chevytrucks.com/vboard/payments.php Great How To Thread http://67-72chevytrucks.com/vboard/s...d.php?t=157669 Vendor Sites http://67-72chevytrucks.com/links/browselinks.php?c=2 Last edited by tommypic; 10-09-2008 at 05:01 AM. |
10-09-2008, 08:50 AM | #20 |
jorgensensc - you are up on the vintage air - what is your zip and I can get you a shipping quote.
I am guessing around $30 but want to be sure... |
10-09-2008, 09:23 AM | #21 |
lks dcvn,
My zip is 77018. I can paypal the money when you give me the total. Thanks for sending this deal back out to us. Pt, Thanks for finding out about your friend so quickly!! I really appreciate it! Tommy, Sorry man, but the wife will not let me miss this one again!! She wants A.C. in her burb so she can start driving it!!! Good Luck to you!!! Ahh. I guess good karma came back around for us!!! Awesome. SHawn
10-09-2008, 02:11 PM | #22 |
Please put me in line for the vintage air.
Thanks. |
10-09-2008, 07:08 PM | #23 |
lks dcvn,
Two questions really quick. First, in the description it says it connects using your deluxe controls. I have been assuming that meant the A.C. Controls. That is correct right? This system doesn't use the heater controls does it? Second, if you will send me your paypal addy I can just paypal you the total with 35.00 for shipping. Then if is right you can mail it off without making a second trip. If it is more for shipping I can send you the difference. If it is less, you keep the difference. How does that sound? Would that work for you? Please add insurance to cover the cost of replacement if damaged (approx 650). If it increases the shipping I will pay the difference. Let me know. Shawn Shawn Shawn
10-10-2008, 02:30 PM | #24 |
1967 LWB Truck - no motor/trans - basically a cab (rusty on the bottom), frame (straight and solid), bed (wood floor) and a tailgate (not great condition - but it works) - interior has been stripped - but it can go with for some extra $ - I do have a clear MI title for this one. Newer tires and rims. $500 obo - you can sell parts (core support/grill/tires/tims/etc.) off this and recoup your costs. 1972 Rolling Chassis - from TX - surface rust only - straight. Trailing Arm frame with 5 lug rollers on it. If you buy this I will throw the LWB (bed) mentioned above on this for you for free and include it in the price - $150 obo Don't toss these yet, I'm interested in some or all of it. I'm in Bucyrus Ohio. Was the 72 chassis a LWB C-10? 5-lug all the way around? How rusty is the '67 cab? Vague question I know, but still.... |
10-10-2008, 02:57 PM | #25 |
Was the 72 chassis a LWB C-10? 5-lug all the way around? Yes on both counts LWB and it has 5 lug rollers on it now that don't hold air well - but I could pump them up to get it rolling around again.
How rusty is the '67 cab? Vague question I know, but still.... Rusty near the bottom - floor - patched with sheet metal and rivets by PO - only on edge - center of cab is pretty solid rockers - created with sheet metal and riveted in - not too bad a job actually inner rockers - gone cab supports - there somewhat - obviously rusting away - and need serious work corners - I can't remember - but can check if you are interested Short answer - could it be used today - no, could it be easily saved if you have a knowledge of welding - yes. STINEY If you take all that stuff - I will give you a bulk discount on these items...let me know. I can get pix of whatever you would like to help your decision one way or another. PM me for details if you want. Thanks |
