turbocharger on a 350?
I've been looking to add a little extra boost to my 350. It was just rebuilt, and was made to be mild, but better than stock, with a mid range everything. I was also hoping to get decent mileage, but that went out the window. I've been very pleased with the outcome, but more is always better, so I was looking to get a turbocharger to add a nice little bit of boost. The problem is, I know absolutely nothing about turbochargers, superchargers, or any of those extras that are used. I didn't build the compression to be much different than stock, though it was bored out .030 over. So basically, I'm looking at what kind of turbocharger (or supercharger, but I think I would have had to built the entire motor to be supercharged, so I ruled that out) I should be getting. And where should I mount it? I've got the all-too-common Hedmans on there.
![]() Join Date: Jul 2007
Re: turbocharger on a 350?
Everything you will want to know and need to know is here--http://www.theturboforums.com/smf/index.php
You will have to change the headers - they actually sell some decent twin turbo headers on ebay for little coin - they do need a bit of work but it will get you started. Last edited by Alex1; 10-09-2008 at 02:14 PM. |
On a budget like Fred Sanford
A turbo motor has basically the same requirements that a supercharged motor does......low compression (9:1 or less), cam w/little overlap, parts that can take the abuse. Cast or hypereutectic pistons don't play well with much boost. You'd need a good blow-through carb setup and requisite upgrades to your fuel system. Turbos are fun, but things get expensive quick.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD Last edited by swb85; 10-09-2008 at 02:22 PM. |
Dr. Frankenstein
talk to Robert1320 on Theturboforums if your serious about adding a Snail under the hood.The dude knows everything and runs his stuff to so hes Legit
I Wanna Go Fast!! |
Dr. Frankenstein
Hands down the Guy is a Turbo Genius
I Wanna Go Fast!! |
Junior Member
What about one of those belt driven jobs, procharger I think is the name of one brand. Least you wouldnt have to change the headers and I believe they make good power.
Just a thought , I probably know less than anybody on this subject.
68 GMC 565 BBC Abruzzi super pro glide 9.85@135.00 ![]() |
The prochargers are awesome as well. Read up on that forum - theres alot of guys running mild combos making a ton of HP with turbos.
Joeys66pickup, I too am going with twins on my BBC. I have all the SS J bends and flanges to build my headers - I had kind of changed my mind but turbo is the only way to go! I'm looking for 800rwhp! I also found a guy on that forum that will weld up my pipes ( I was going to do it myself but...) for $450 - so the pipes are going out at the end of the month Turbos rule! Last edited by Alex1; 10-09-2008 at 06:24 PM. |
Dr. Frankenstein
i decided purely on Cash.....8-71 roots like $3000 for the kit alone
![]() Is the BBC going into the Truck on your Avatar Alex1? mine will find a new home under the hood of my 57' shortystepside in a month or two
I Wanna Go Fast!! |
Yep its going into my 80 step - it already has a 454, but I have another 4 blt block, dart pro1 heads 4340 crank and rods that will be built for the turbo set up. Should be interesting!
Well I'm still at 8.5:1 compression, so I'm not worried about that. But my brother also gave me the idea of a centrifugal supercharger. Its actually pretty difficult to find a good explination for whether these are truly just a bolt-on or if they require more, anyone want to tell me about it in a nutshell? Could I just bolt on a centrifugal without any problems? How does it install?
You can buy a kit that will get the blower installed, all the brackets, pulleys blow off valve and piping in included. You will need a fuel pump and proper fuel lines and regulator as well as a blowthrough carburetor - go with a CSU or C & S blow through carb. If you keep it on 8psi or less you 'should' be OK with hypereutectic pistons but forged are better - there's no need for an intercooler with a carb at this level of boost. Don't forget you only get your set limit of boost at the peak rpm - so lets say you want 8 psi and max 55-6000 rpm then you pulley it for 8 psi at that rpm. This means you have little boost below lets say 4000rpm. The F1 or F2 are nice but they are pretty serious peices, there are smaller models available for less $$
Check this out. http://www.ssautochrome.com/level.itml/icOid/1844. I know nothing about turbo engines but I'm becoming very interested. Only thing I don't see is piping and a carb.
#14 | |
#15 |
I don't know anything about the quality of the turbos or even who makes em. but it is by far the cheapest kit I've seen. Even so, your still looking at the Carb, Piping, and I think you have to have a boost referenced ignition/fuel system. One or the other. I'm definitely gonna do some research on it. Don't think I've ever seen a turbo truck before. Think I might consider going this route versus the big block.
#16 | |
You buy the headers from them - cut off the flange and have a t4 304ss flange welded back and add a tube for an external wastegate. then you can use whatever t4 turbos you like. |
#17 |
Registered Truck Offender
Do yourself a favor,, if your thinking of a Procharger or boost of any form,, pull the motor apart and put true forged pistons in it. One way or another you'll be doing it anyways. Always best to do it BEFORE the damage occours. Just like Nitrous,,, Boost is addictive and you WILL get greedy, crank up the boost and melt a couple of cast pistons. Hypereutectics are harder,, MUCH harder, even to the point of being considered brittle when introduced to Mr detonation. All it takes is one booboo with boost and hypereutectics and you have an empty hole where the piston used to be. Again the resulting damage is typically pretty expensive. I've seen a couple of motors that the 'mild detonantion' lifted a ring land,, the chunks of piston were smashed against the head/valves, bending valves, etc. Your going to spend around $2k for a turbo ot procharger,, add $625 for a set of SRP forged pistons to protect your investiment. Well worth the money.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
#18 |
Turbo Guy
I used the same turbos and headers from them in my truck. The turbos are hit and miss for quality, I got a good set I was lucky. I run twins at 12 psi non intercooled on a stock 305. This winter I am going to a 350 with some cam and more carb, and an intercooler. I want to run 15psi and with the combo I have I think I can get it around 500 horse at the wheels
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles. 1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit! Things I've broken so far: 12 bolt diff saginaw 4 spd many, many pieces Aluminum case Super t-10 4 spd |
