10-11-2008, 02:41 PM | #1 |
It'd be alot cooler if you did
Sway Bar thread
I've noticed there has been some talk on here lately of adding aftermarket sway bars, and it seems there is some confusion as to what works and what parts to get. I have had a few head aches with it myself here in the last month, and thought we could use a thread of what works and what doesn't. So if you have an after market sway bar on your truck, post up the brand name, where you got it, and the specs on it.
I started out with this one from Summit Racing: http://store.summitracing.com/partde...5&autoview=sku It didn't work at all. It was way too wide, and when I finally talked to tech support at Summit they said it wasn't even the right part number. So, after talking to the guy for a while, I ended up with this one from Bell Tech: http://store.summitracing.com/partde...5&autoview=sku This one was much more narrow, and also 1/4" fatter (1-3/8" overall). I then fabbed up some mounts on my control arms, bolted in the links, and drilled the holes in the frame. It turned out quite nicely I think. From center to center of the end links it measures 40-1/4". I could probably have had a custom one made a few inches wider, but at this width everything is pretty tidy. Here's some pics. Everyone else please post up how you got your Anti-sway bar mounted and the specs on it. Last edited by smashingchuck; 10-11-2008 at 02:43 PM. |
10-12-2008, 09:00 PM | #2 |
Happy to be here
Re: Sway Bar thread
Anyone?
10-12-2008, 09:26 PM | #3 |
Re: Sway Bar thread
Did you guys see the one they used on the SD front dropped crossmember?? i believe it was a zq8 one..
10-12-2008, 10:47 PM | #4 |
Re: Sway Bar thread
10-12-2008, 10:09 PM | #5 |
Manual Transmission Club
Re: Sway Bar thread
I bought that same Addco 117, I haven't installed it yet but when I do I’ll post picks here.
79 GMC Sierra Grande, SWB, Heavy Half If I wanted easy I would just buy a NEW truck! |
01-17-2009, 11:23 AM | #6 |
Re: Sway Bar thread
smashingchuck, what arms to you have? Would this setup work with ART arms and a sectioned crossmember?
You couldn't use the factory holes on the frame to bolt on the mounts? |
01-18-2009, 12:49 AM | #7 |
Bodydropped71
Re: Sway Bar thread
I have upper and lower Thorbecke arms with a stock crossmember. What sway bar would i need? My truck is bodydropped btw
01-18-2009, 07:51 AM | #8 |
Re: Sway Bar thread
Theres only one way to find out. Call them. Those arms are new and there is not much info here about them yet. Let us know what they say.
01-18-2009, 08:49 AM | #9 |
67-72 parts collector,…
Re: Sway Bar thread
They only sway bar that will work is the AirRide Technologies MuscleBar part # SWA-7800. I have the TB arms on my crusty '71 2wd blazer, It's high priced,... but the only one that will work with the TB arms and the ART arms.
01-18-2009, 10:00 AM | #10 |
Re: Sway Bar thread
Am i to understand that a factory swaybar wont work at all or needs mods?
My Project Old Glory trike visit here http://www.facebook.com/home.php?#!/...48577705162172 |
01-18-2009, 02:28 PM | #11 |
Re: Sway Bar thread
01-18-2009, 11:45 AM | #12 |
Re: Sway Bar thread
The Muscle Bar is definitely the nicest on the market, but at over $300 is was hard for me to justify it. once I get my truck on the road maybe that need will change, but I think the one I used should work fine.
01-19-2009, 02:25 AM | #13 |
Re: Sway Bar thread
IMO, the problem with the stock ones is they just slide into the mounts on the control arm and therefore are not mounted safely enough for my liking.
