10-12-2008, 07:20 AM | #1 |
z-ing my frame
I want to z my frame on a 67 suburban.I tried using search first couldn't find anything. what I'm trying ti find out is if I z the front.Am I gonna have to cut the floor for the trans.thanks for the help.
10-12-2008, 11:47 AM | #2 |
Re: z-ing my frame
how big is the Z?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
10-12-2008, 11:56 AM | #3 |
c10 Chop Artist
Re: z-ing my frame
It also depends on which transmission tunnel you have (3 spd or 4 spd).
10-12-2008, 07:39 PM | #4 |
Re: z-ing my frame
I think its 3 speed.how much more room will a 4x4 hump give me.so I can put as much of a z as I can.
10-12-2008, 10:11 PM | #5 |
c10 Chop Artist
Re: z-ing my frame
A 4spd hump will give you more room. you only need to do about a 2 inch Z to lay the truck flat if you are going to bag it. You should be able to do a 2 inch with a 4spd hump, no problem. But you will have to make a tunnel for the driveshaft.
10-12-2008, 10:50 PM | #6 |
Re: z-ing my frame
Or use the 2 piece driveshaft should help with the driveshaft issues.
10-13-2008, 05:24 PM | #7 |
Re: z-ing my frame
it has a 2 piece.I gonna need a hump then.as far as the tunnel I guess I'll play that by ear.
10-13-2008, 06:01 PM | #8 |
3DrDwn--the 'burb not the band
Re: z-ing my frame
I have a 72 burb with a 2" raised x-member( I know not a z but since the questions are driveshaft/trans hump related)
I had the low hump and had to cut out for my trans. My driveline is super close to the floor and may now need a tunnel. It didn't before I removed the body but it was close enough to make me consider one. I'll know more once I put the tub back on. I removed the body to work on the rear notch/4link. Josh
Slo and Lo that is the tempo. '72 burb build page here: http://67-72chevytrucks.com/vboard/s...d.php?t=259256 '89 GMC Dually crew build page coming soon. 88 4x4 crew DD duallys past/present pics here: http://67-72chevytrucks.com/vboard/s...46#post4001246 89 1 ton Dually rear flip kit install here: http://67-72chevytrucks.com/vboard/s...d.php?t=354327 |
