73-87 disk brakes on a 67-70
I want to put power disk brakes on my 67 chevy c10 (69 rolling chassis) and I'm on a tight budget, can I get 73-87 parts from a junk yard, are they interchangable? If so what parts wood I need? Any help would be apriciated
1967 LWB 4speed-current project ![]() 1970 LWB 3 speed -stolen ![]() 1980 Z28 - sold 1968 Barracuda Big block- sold ![]() 1969 Firebird 400/400-sold |
#2 | |
Re: 73-87 disk brakes on a 67-70
I bought the arms, calipers, spindles, splash shields, master cylinder, pwr. booster, prop valve + hardlines, & the drag-link from a wrecked truck when I did this swap on my 68. I used the master cyl, booster, & calipers as cores toward new parts (the master cyl & booster I exchanged for 71-72 year model). The brake lines had to be slightly tweaked but fit & look factory. The prop valve was relocated to the front splash pan vs under the master cyl like 67-72's but since I grabbed the hard-lines that was just an R&R excersize. On my truck I re-used the original steering box because I was keeping it manual steer, but you can use the pwr box from the donor as well if you didn't have pwr steering (although 67's require some additional bracing @ the inside of the frame).
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-13-2008 at 11:45 AM. |
#3 | |
Vortec in the works
I did the samr thing but was wondering what coil spings to use. I have a pair of 2'' lowering coils from a 68, will they work in the 73-87 arms?
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
Seņor Member
Yes.
Texas Big Wig
If your get the chance, get the 1-1/4" wide rotor brakes instead of the 1"
Also, try to get as much of the system as possible I do believe that the upper ball joints are different, but the lowers are the same |
Droppin' It Like It's Hot!
Excellent information here. I might be acquiring an 85 C10 and was wanting to convert my 69 over to the disc brakes. I was thinking about swapping over the whole cross member, but if the a-arms and spindles will swap then I will just do that. Anyone know if the rear end assembly will swap over or what modifications would need to be done? The 85 is leaf spring and mine is coil spring. I want the five lug axles out of the 85 to match the front disc. Would it be easier/possible to just swap the axles and/or gears and axles? Any other pointers would be great!
Robert
Life Member RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09 1969 ![]() Norwood, MO 2007 Big Sandy, TN 2008 Had nothing to do with the forklift! Kirkwood, MO (Midwest Meet 2009) Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014 SUPPORT THE SITE HERE! |
#8 | |
ECE & CPP both make the needed brackets for the swap. You'll need to cut off the leaf related brackets & weld the trailing arm related brackets on (after determining your pinion angle & making sure everything is centered). Another option is both of those companies make axle swap kits that allow removing your 6-lug axles & swapping in new, aftermarket, 30% stronger axles. I like this method & feel it's easier than all the swapping, grinding , & welding req'd when swapping to the leaf spring housing. If your on a tighter budget & don't mind the labor, swapping the housings you already have would cost less. For the record..... If you don't mind the 6-lugs, several board vendors sell 6-lug rotors that will work w/the disc swaps. The only downside is when you need new rotors, you can't run down to your local parts house. This is the easiest way to get matching lug patterns. They're about ~$20 more than regular 5-lug rotors but save you a bunch of work.
That is a good option as far as the 6 lug rotors...Have any names of the board members that sell them?
Robert
Classic Heartbeat (Wes)
GMC Paul ECE CPP
Thanks for the info!
Robert
